Head shave - 20v silvertop
Postby Flannelman » Tue Jan 25, 2011 10:06 pm
Wishing to pump up the compression on a Silvertop.
Im aware of .8mm TRD gaskets and flat top pistons to give it a boost but how much can the head be plained before there comes complications in weakening the head?
Flannelman
formerly known as Affroman
Re: Head shave - 20v silvertop
Postby ace_nz » Tue Jan 25, 2011 10:18 pm
Flannelman wrote:Wishing to pump up the compression on a Silvertop.
i've taken 2mm off with no issues. Will effect cam timing a bit though.
ace_nz
Postby cat007 » Tue Jan 25, 2011 11:31 pm
How much clearance is there normally between the piston top and valves? Or are they already an interference engine?
Postby Flannelman » Wed Jan 26, 2011 6:31 pm
Around 9mm with stock pistons and head gasket installed.
Stock silvertop is non-interference
ace_nz, cam timing can be fixed with adjustable cam gears?
Flannelman
Postby ace_nz » Thu Jan 27, 2011 10:49 pm
yep, you can correct the timing with gears, but the inlet being vvt makes it a bit tuff.
ace_nz
Postby CAMB01 » Sat Jan 29, 2011 2:03 pm
Yes adjustable cam gears will be needed to adjust the slack in the timing belt.
Ive taken 1mm off my block and the top of the pistons in my EVO to raise compression slightly. Had to grind a bit off the top of the engine mount and a bit off the back timing cover tins cause when i fitted the head they were holding it off the block.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby TRD_ZERO » Tue Feb 01, 2011 7:32 pm
You cut up your pistons? Doesn't that mess with the integrity of the pistons?
Previous:
TRD_ZERO
Postby Boost_4_Life » Tue Feb 01, 2011 7:55 pm
not if you use a good hacksaw.
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby TRD_ZERO » Tue Feb 01, 2011 8:33 pm
Oh ok, just use pro tools and it's ok.
Previous:
TRD_ZERO
Postby Flannelman » Fri Feb 04, 2011 6:08 pm
removing material from pistons would lower the compression ratio...
skimming the block would bump it up
Flannelman
Postby QikStarlie » Fri Feb 04, 2011 7:52 pm
i'd say he would have machined the pistons in the squish area, to avoid piston to head contact.
QikStarlie
Postby CAMB01 » Sat Feb 05, 2011 6:32 pm
Flannelman wrote:removing material from pistons would lower the compression ratio...
Not if you take material off the top to make the dish in the piston smaller.
All machining was done by me using a lathe and milling machine.
CAMB01
Postby AceSniper » Tue Feb 08, 2011 7:18 pm
Still going to lower it, or you run longer rods to bring the pistons up higher?
AceSniper
Postby CAMB01 » Tue Feb 08, 2011 7:34 pm
Hence why i decked the block to suit.
CAMB01
Postby AceSniper » Tue Feb 08, 2011 8:49 pm
:D sorry my bad not reading complete story
AceSniper
