what did you want to know? I have wired a beams engine into my lotus 7 with orginal ecu and dash.. not sure if it works yet, but it should be all good as my wiring diagrams were used to wire that
RomanV is using the single vvti redtop version so wiring is simpler than the altezza set up (no multiplexing etc)
^what they said. to add to the other thread, just get a aftermarket ECU that can do VVTI. Whats the budget?
Some people have tapped a thread into the far end of the Altezza fuel rail and converted to a fuel return system, but you need an FPR which can run at a high enough pressure to suit the factory settings.
Just mechanically, built into the fuel pump I believe.
I think there's a pressure dampener on the fuel rail to help stop pressure spiking up or down at the rail end.
