3sge on a angle?
3sge on a angle?
Postby 88.4ageGT » Mon Feb 07, 2011 9:39 pm
hey guys just a random questions why are 3sgte/3sge mounted on a angle in the engine bay in sum toyotas??
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Postby Dell'Orto » Mon Feb 07, 2011 9:54 pm
Bonnet clearance I assume, possibly weight distribution reasons.
Postby Truenotch » Mon Feb 07, 2011 10:05 pm
Bingo and bingo.
Do you want to stand one up?
Truenotch
Postby evil_si » Mon Feb 07, 2011 10:28 pm
Oil drain from the head?
evil_si
Postby Adamal » Mon Feb 07, 2011 10:48 pm
evil_si wrote:Oil drain from the head?
Yea, that was the impression that I got.
Postby MAC_HATER » Mon Feb 07, 2011 11:02 pm
i was just under the assumption some toyota factory assemblers were larkign about with a 3S-GE and an engine stand and it fell into a car engine bay while they were trying to hit guys with a flying engine and it was 4.30 on a friday and they just went "eh close enough" and welded that $&#$% in there - and they just did that from then on ;)
MAC_HATER
Postby h8wrxs » Mon Feb 07, 2011 11:11 pm
MAC_HATER wrote:i was just under the assumption some toyota factory assemblers were larkign about with a 3S-GE and an engine stand and it fell into a car engine bay while they were trying to hit guys with a flying engine and it was 4.30 on a friday and they just went "eh close enough" and welded that $&#$% in there - and they just did that from then on ;)
its what id do if i worked at toyota, so must be right :D
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby RomanV » Tue Feb 08, 2011 12:35 am
It's quite a tall motor otherwise!
Leaning it over makes sense, seeing as how they were only ever in transverse layout up until the Altezza.
(Not counting 1S and 2S, of course)
Postby Adamal » Tue Feb 08, 2011 6:44 am
If they had laid it on its side, would it sound like a Subaru?
Postby ch4ng » Tue Feb 08, 2011 7:18 am
Adamal wrote:If they had laid it on its side, would it sound like a Subaru?
8O
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby sergei » Tue Feb 08, 2011 8:31 am
8O
No, but leaked like one :lol:
Postby MilfHunter » Tue Feb 08, 2011 9:02 am
All the above plus I read somewhere that it improves balancing and somehow raises the torque slightly.
MilfHunter
Postby Adamal » Tue Feb 08, 2011 9:18 am
Well, 190nm is slightly on the lower side of what I'd expect from a twin cam 2 litre N/A :lol:
Postby MilfHunter » Tue Feb 08, 2011 9:29 am
I presume you're referring to the 26yr old versions still running on the original bearings and rings?
You forget a) Those motors had T-VIS which extended it throughout the rev range. b) The ST162 has a 250kg weight advantage over the ST182,202 etc
MilfHunter
Postby MAC_HATER » Tue Feb 08, 2011 9:40 am
MilfHunter wrote:I presume you're referring to the 26yr old versions still running on the original bearings and rings?
you mean the ones that the owners forgot to service and drove around for 15,000km on the same oil and then were cheap $&#$% and just changed the oil with the cheapest oil possible off a mates friends mates uncles mate who has hookups for cheap unbranded oil and doesnt change the oil filter at the same time?
MAC_HATER
Postby Mr Revhead » Tue Feb 08, 2011 9:43 am
Purely for lower bonnets/frontal area.
Nothing to do with oil draining or more torque. How does that work? :?
Although as Sergei mentioned it does help the oil drain down the back of the block :lol:
Postby Adamal » Tue Feb 08, 2011 1:18 pm
No, I'm referring to Toyota factory figures.
Postby cat007 » Tue Feb 08, 2011 1:33 pm
I think it's so any BHG that leaks out, runs down the side of the block rather than into the piston bore chambers.
Postby RomanV » Tue Feb 08, 2011 2:21 pm
Mr Revhead wrote:Nothing to do with oil draining
All of the oil galleries which drain the oil back down from the head down to the sump again, are on one side of the engine.
This works well enough, because the engine is tipped over to drain the oil in that direction.
When you stand it up, it cant drain the oil out of the head quickly enough and the whole thing fills with oil hahaha.
Altezza motors have got an additional external oil drain from the head back to the sump for this reason, as well as (apparently) smaller diameter oil feed lines to the head.
About the more torque thing... Hmm, pistons arent pushing against gravity as much? :lol:
Postby Adamal » Tue Feb 08, 2011 3:09 pm
RomanV wrote:About the more torque thing... Hmm, pistons arent pushing against gravity as much? :lol:
But that means that gravity isn't helping pull the pistons down on a firing strong as much!
Rembmer: Its and Infernal Contradicting Engine!
