Malcolm wrote:I didn't know they had maths on waiheke
evil_si wrote:Oil drain from the head?
MAC_HATER wrote:i was just under the assumption some toyota factory assemblers were larkign about with a 3S-GE and an engine stand and it fell into a car engine bay while they were trying to hit guys with a flying engine and it was 4.30 on a friday and they just went "eh close enough" and welded that $&#$% in there - and they just did that from then on
Adamal wrote:If they had laid it on its side, would it sound like a Subaru?
MilfHunter wrote:I presume you're referring to the 26yr old versions still running on the original bearings and rings?
You forget a) Those motors had T-VIS which extended it throughout the rev range. b) The ST162 has a 250kg weight advantage over the ST182,202 etc
Mr Revhead wrote:Nothing to do with oil draining
RomanV wrote:About the more torque thing... Hmm, pistons arent pushing against gravity as much?
Users browsing this forum: Bing [Bot] and 2 guests
