Removing the standard roof racks on a 1998 Caldina
Postby imat89 » Tue Feb 08, 2011 9:51 am
Hi everyone!
Does anyone know how hard/how to remove the factory roof racks on a 1998 Toyota Caldina?
Thanks in advance,
Matt
Proud owner of a 1998 Toyota Caldina!
17" avantis, slammed on 50mm king springs, hid headlights, rps muffler, sony panel headunit and speaker system! Boyyaah!
imat89
Postby cat007 » Tue Feb 08, 2011 1:10 pm
Tie roof racks to tow bar of another car
Engage first gear
Floor it whilst pressing the TURBO BOOST button
Roof racks successfully removed
Postby ch4ng » Tue Feb 08, 2011 5:53 pm
looks like you have to remove your roof lining and unbolt from there if there are no covers for bolt heads topside.
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby diss7 » Tue Feb 08, 2011 7:35 pm
Forklift.
Can use it for pumping the guards as well.
diss7
Postby Bling » Tue Feb 08, 2011 7:39 pm
Maybe ask your mrs is she is up to the task if you're unsure you can manage :lol:
What have you tried so far?
Postby fivebob » Tue Feb 08, 2011 7:52 pm
Not recommended unless you're replacing them with something else to give strength to the roof.
Postby Caldina3SGTE » Tue Feb 08, 2011 8:15 pm
depends if you just want to take the racks off and not the mounting points if so its a easy job just remove the cover on end of each rack and undo 14mm or 12mm bolts and lift off,
if you wanna remove the mounts aswell its a huge job you first gotta take the roof lining off so to get that off you have to remove boot trim side pillar trim, then if you have a sun roof you gotta drop that down then you can remove the mounts by unbolting them, now you have 8 wholes in your roof,
i've had mine off for a few months now and am now thinking why i took them off as they are very handy to have
Caldina3SGTE
Users browsing this forum: Bing [Bot] and 23 guests
