1g block differences
Postby Townace » Fri Feb 11, 2011 9:17 pm
Do 1g-ge and 1g-fe share the same block? and did the engine mount castings change once the engine went vvti?
Townace
Postby Brawler » Fri Feb 11, 2011 10:19 pm
What are you trying to do?
zing! Sig got nuked. Sorry bout that.
Brawler
Postby al_feinted » Sun Feb 13, 2011 9:43 am
I thought if toyota made any major changes to the block it would have been renamed to a 2G-FE? Or do they only change the number if the capacity changes?
Engine mounts are unlikely to change due to vvti, more likely to differ depending which car the motor is from. (Example GXE10 altezza or GX100 chaser)
Project cars: 83 corona tt142, 83 corona mark2 gx61, 82 avante chaser gx61.
www.toycrazy.net
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1408
al_feinted
Postby Townace » Mon Feb 14, 2011 4:36 pm
Interesting cheers, contemplating a 1g-fe conversion into my hilux.
1g-ge is an easy conversion from looking on the net but are old tech so was considering a 1g-fe since you can pick up a import engine cheap enough and the utes a daily driver so useable power and economy are what im looking for
Townace
Postby AE86less » Mon Feb 14, 2011 5:40 pm
1G-FE is quite a nice engine, great at what they're designed for.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Brawler » Mon Feb 14, 2011 6:56 pm
1GGEs are the shit!
Brawler
Postby Townace » Mon Feb 14, 2011 9:24 pm
Brawler wrote:1GGEs are the shit!
They are indeed would be using a 1GGE if it wasnt my daily
Townace
Postby cat007 » Tue Feb 15, 2011 5:23 pm
What you really want is a 1GZ-FE hehe ;)
Postby Townace » Tue Feb 15, 2011 7:59 pm
cat007 wrote:What you really want is a 1GZ-FE hehe ;)
dreams are free
Townace
Postby UTERUS » Wed Feb 16, 2011 2:08 pm
The only 1G-FE i would consider using is the beams version, the older gen fe's are ok but they don't like to rev like the ge does.
But really, I would go straight for a 1/2JZ-GE, they aren't as expensive as they used to be and are such a superior motor.
UTERUS
Postby mjrstar » Wed Feb 16, 2011 7:30 pm
^^ Speaks the truth.. 1g's are a pain to modify / get parts for.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby Brawler » Wed Feb 16, 2011 8:38 pm
Maybe a little easier in japan...
http://www.youtube.com/watch?v=PCtNLJUD ... r_embedded
I want that engine!
Brawler
Postby Townace » Wed Feb 16, 2011 8:39 pm
beams 1g-fe was what I was planning on using
1jz-ge had crossed my mind
Townace
Postby mjrstar » Thu Feb 17, 2011 12:23 am
this is mine on the old motor (about 3 years ago) it has had a couple of bigger turbos since then...
http://www.youtube.com/watch?v=QrM43jsoTS8
sorry we talk crap about FPR plumbing for a bit before the loud pedal gets mashed..
current cars:
Evo 4 230Kw atw
1971 mini.
mjrstar
Postby Brawler » Thu Feb 17, 2011 6:03 am
did you ever blow the 1gge block lol?
Brawler
Postby UTERUS » Thu Feb 17, 2011 3:30 pm
Seriously, I would never consider a 1G anything for a commercial vehicle.
I'm not just wanking on about 1g hate, It's just that the jz engines are that much better, and you will thank me later.
UTERUS
Postby cat007 » Thu Feb 17, 2011 3:38 pm
UTERUS wrote:Seriously, I would never consider a 1G anything for a commercial vehicle.
Unless weight and space is an issue
If it's not - why not go for a supercharged 350 chev? :roll:
Postby Townace » Thu Feb 17, 2011 6:47 pm
Can a 1jz-ge be wired in with the factory ecu easily enough, if I was going 1jz I would get the vvti version
Townace
Postby UTERUS » Thu Feb 17, 2011 7:26 pm
Weight and space isn't an issue for a 1jz in a hilux, stop being a dweeb.
Yep to factory ecu, that's not a problem.
UTERUS
Postby 1I1 » Thu Feb 17, 2011 8:18 pm
al_feinted wrote:I thought if toyota made any major changes to the block it would have been renamed to a 2G-FE? Or do they only change the number if the capacity changes?
The number at the start will denote size. ie 1JZ vs 2JZ :wink:
TRD Clicky >>Here
1I1
