i have been using a synthetic 75W 140 LS gear oil in AE86 2 way.
Wondering what others have been using?
TRD LSD oils? what do you use
Motul gear competition
Castrol SAFXA is meant to be the one to use these days, and its real cheap to buy from a Ford dealer.
- Dell'Orto
- ** Moderator **
Geartech recommended me 80w140 Redline for mine
Motul comp gear oil, its expensive but so is rebuilding gearboxes
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
ke25sr wrote:RD require a multi grade, the LS 90 type oils are not right unless you running a stock LSD
I'm interested to know what the difference between a T293 factory LSD and an early TRD T series LSD is?
Toyota mechanics considered opinion was to use the multigrade oil for racing (more bite) and the 90 on the street (smoother).
Info from TRD Website, the FF type TRD LSD still is recommended to use a LS90
TRD LSD oil FR is a multi-grade gear oil developed for differentials in vehicles equipped with an LSD. This 85W-140 grade oil maintains its viscosity index across a wide range, and exhibits superior oil film characteristics under both heavy loads and high temperatures, thanks to its special pressure and wear agents, which help to soften shocks and maintain gear teeth. What's more, its special friction-regulating agent maintains the ultra-high LDS performance that is demanded by motor sports and other extreme driving activities.
