Malcolm wrote:I didn't know they had maths on waiheke
Brawler wrote:Why does oil even go back into the intake, wouldnt it just get burnt? I can only think of negative reasons for doing so
h8wrxs wrote:what is the reason for upgrading to a catch can in the first place, why dont standard cars run them?
iOnic wrote:What's the point: During normal operation some combustion pressure leaks past the piston rings into the crankcase causing it to pressurise. This pressure needs to be vented somewhere otherwise it causes seals to blow out, bad oil drainage internal drag which = less efficiency etc etc. In early systems it was just vented to the atmosphere. Nowadays with emissions standards (actually since about the 80's) it's not really environmentally friendly to vent oily vapours into the atmosphere so there are crankcase venting systems in cars that vent the oily vapour back into the intake of the car to get sucked up by the engine and burnt off - makes the hippies somewhat happy (hippies are never completely happy), hippies buy said cars, car manufacturers are happy.
Trouble with your engine sucking in oily air though is that it reduces the effective octane level of your fuel which can = detonation and therefore lower performance. Not a problem on a factory car - can be a problem on a modified car that is closer to the safe limit. People that like going fast don't like this. That and it makes your intake/turbo etc oily and generally scody.
Catch can (depending on design) catches the oily vapor, separates oil/air, vents the air to atmosphere (or back into intake minus the oil) and stores oil in a can that you can drain later. Some drain the oil straight back into the block/sump so it's a completely closed system.
Bit more to it but in a nutshell that's basically it. Some cars have factory catch tanks eg: 93/94+ Turbo MR2
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
