catch tanks
Post Reply
88.4ageGT
catch tanks
Post by 88.4ageGT »
whats the best way to put a catch tank into a 4age
cam cover to tank? back to manifold?
thanks
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
MAC_HATER
Post by MAC_HATER »
yeah thats how i did mine years back - any blowby that pushes oil out the cam cover gets caught in the tank and the air continues to the intake that way
didint get to use it long enough to get a proper gauge on its effectivness though but its the logical way i think anyway
Brawler
Post by Brawler »
Why does oil even go back into the intake, wouldnt it just get burnt? I can only think of negative reasons for doing so
zing! Sig got nuked. Sorry bout that.
Quirky
Post by Quirky »
Brawler wrote:Why does oil even go back into the intake, wouldnt it just get burnt? I can only think of negative reasons for doing so
In Australia, it has to be plumbed back into the intake.
Otherwise the fumes are deadly or something.
Mines just vented to atmo, smells AWESOME
Hello There
h8wrxs
Post by h8wrxs »
what is the reason for upgrading to a catch can in the first place, why dont standard cars run them?
Contact:
Post by iOnic »
What's the point: During normal operation some combustion pressure leaks past the piston rings into the crankcase causing it to pressurise. This pressure needs to be vented somewhere otherwise it causes seals to blow out, bad oil drainage internal drag which = less efficiency etc etc. In early systems it was just vented to the atmosphere. Nowadays with emissions standards (actually since about the 80's) it's not really environmentally friendly to vent oily vapours into the atmosphere so there are crankcase venting systems in cars that vent the oily vapour back into the intake of the car to get sucked up by the engine and burnt off - makes the hippies somewhat happy (hippies are never completely happy), hippies buy said cars, car manufacturers are happy.
Trouble with your engine sucking in oily air though is that it reduces the effective octane level of your fuel which can = detonation and therefore lower performance. Not a problem on a factory car - can be a problem on a modified car that is closer to the safe limit. People that like going fast don't like this. That and it makes your intake/turbo etc oily and generally scody.
Catch can (depending on design) catches the oily vapor, separates oil/air, vents the air to atmosphere (or back into intake minus the oil) and stores oil in a can that you can drain later. Some drain the oil straight back into the block/sump so it's a completely closed system.
Bit more to it but in a nutshell that's basically it. Some cars have factory catch tanks eg: 93/94+ Turbo MR2
Contact:
Post by matt dunn »
h8wrxs wrote:what is the reason for upgrading to a catch can in the first place, why dont standard cars run them?
As cars would never pass emissions regulations required without them.
MAC_HATER
Post by MAC_HATER »
yeah its great - when i go WOT in the celica it just pisses oil into the intake and i get an awesome smokescreen that makes vegans cry :D
yeah the 3S-GE is about facked ;)
Brawler
Post by Brawler »
could probably hore up one with a garden hose and a coke bottle
MAC_HATER
Post by MAC_HATER »
thats pretty much what most catch cans are - something to disrupt the airflow so the oil stays in the bottle while the air goes back out
some really expensive cans do other things but your average $80 simota can is just a can with 2 holes in it and a oil level gauge thing ;)
ATAl
Post by ATAl »
Just run a hose from both air vent lines in the cam cover under the car and into the air stream, cheapest way to do it and it's effective.
allencr
Post by allencr »
Put the cam cover with the vent on the exhaust side. With that swap, the blowby from your tired engine will have a more direct route out and won't take nearly as much oil along for the ride.
88.4ageGT
Post by 88.4ageGT »
i kinda understand that but can u draw a diagram or show me a picture of this?
thanks
AE92 4age GTi
allencr
Post by allencr »
88.4ageGT wrote:i kinda understand that but can u draw a diagram or show me a picture of this?
thanks
No. Sorry.
Crucible
Real Life Mechanic
Post by Crucible »
iOnic wrote:What's the point: During normal operation some combustion pressure leaks past the piston rings into the crankcase causing it to pressurise. This pressure needs to be vented somewhere otherwise it causes seals to blow out, bad oil drainage internal drag which = less efficiency etc etc. In early systems it was just vented to the atmosphere. Nowadays with emissions standards (actually since about the 80's) it's not really environmentally friendly to vent oily vapours into the atmosphere so there are crankcase venting systems in cars that vent the oily vapour back into the intake of the car to get sucked up by the engine and burnt off - makes the hippies somewhat happy (hippies are never completely happy), hippies buy said cars, car manufacturers are happy.
Well put. :)
Post Reply
