AE111_JAMES wrote:as with the ecu plugs...both auto and manual ecus use the same plugs on the blacktop, is the correct?
but the only difference with the auto and manual looms is the pin out for the gearbox?
AE25 wrote:All (BT) have the same pin outputs except for AT specific outputs on AT models that can be ignored for MT applications."
so we can assume this means the plugs are the same pin count but have extra pins for the auto outputs
nzhogrider wrote:AE111_JAMES wrote:as with the ecu plugs...both auto and manual ecus use the same plugs on the blacktop, is the correct?
That's what it boils down to. So if you have a manual ECU you can use an auto loom and just ignore the auto specific pins. You may need to change 1 or two plugs for the loom to fit the gearbox, unless they are all on the auto loom and are left redundant. i.e. for the neutral and reverse switches, unless of course these are on the chassis side of the loom and not the engine one?AE25 wrote:All (BT) have the same pin outputs except for AT specific outputs on AT models that can be ignored for MT applications."
