AE92-5ONIC wrote:MAP sensor
Timing
Spark
Do diagnosis, MAP sensor would be my best guess.
KIPH8N wrote:AE92-5ONIC wrote:http://www.troublecodes.net/Toyota/
looks quite confusing
nz_climber wrote:take it to a mechanic.
328FTW wrote:I had an issue like this. The centre of the electromagnetic pulley for the supercharger had come clean off, must have come loose.
But still mechanic is in order. If you can have it compression tested and right down what he says. Loads it could be, coil breaking down etc etc
TRD_ZERO wrote:KIPH8N wrote:AE92-5ONIC wrote:http://www.troublecodes.net/Toyota/
Go in the enginebay look for a small black box that says diagnosis. Open it up. grab a paper clip or any sort of wire and jam one end in the terminal TE1 and the other end in E1 (there should be some sort of labeling as a reference). Now go and turn ignition on so that the lights come up on the dash eg.oil, brake, check engine light etc. Dont start the car.
follow the easy instructions below
Count number of flashes from CHECK ENGINE light.
If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
and evenly about 2 times a second.
Otherwise, the light will blink a number of times equal to the trouble code as follows:
The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected.
When finished, remove the jumper wire.
Its that easy.
You might have to do the count a few times to make sure you have the correct codes.
Get into it and start learning how to do some shit yourself.
KIPH8N wrote:Some belt on the car makes a sqiky sound when accelerating i think its the supercharger belt. Could that be an issue?
Adamal wrote:KIPH8N wrote:Some belt on the car makes a sqiky sound when accelerating i think its the supercharger belt. Could that be an issue?
Well that sounds like the electromagnetic clutch is engaging, but the belt might need replacing. Check to see if its hard and cracked.
KIPH8N wrote: Does repco sell them?
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
