4agze blue smoke video up
Postby KIPH8N » Fri Mar 18, 2011 5:52 pm
My 4agze idling is rough and when i put my foot on throttle and than take it off the engine stops running(stalls).
Stuck valve?
What do you guys thing the problem is?
http://www.youtube.com/watch?v=ch0CUP6N-DI
The blue smoke.
http://www.youtube.com/user/2MJPWA?feature=mhum
Supercharger seal?
Piston rings.
Valve seal?
KIPH8N
Postby Mr Revhead » Sat Mar 19, 2011 8:08 am
Has it just started on it's own or have you been working on it?
Btw your avatar looks a little odd....
Postby ~SlideWays~ » Sat Mar 19, 2011 9:21 am
Like a penis? Yeah now that you mention it...
For the idle problem, is it AFM and has it been tampered with? If so that might be the cause. Other wise you can try cleaning it.
~SlideWays~
Postby KIPH8N » Sat Mar 19, 2011 2:44 pm
Mr Revhead wrote:Has it just started on it's own or have you been working on it?
it started on its own.
KIPH8N
Postby KIPH8N » Sat Mar 19, 2011 2:45 pm
its a ae101 so it has a MAP sensor.
KIPH8N
Postby KIPH8N » Sat Mar 19, 2011 3:02 pm
Just uploaded a video on youtube of it. Yes its the power steering belt which is making that noise. It needs to be tightened. Can anyone help me please.
KIPH8N
Postby Dell'Orto » Sat Mar 19, 2011 3:54 pm
Check your plugs for a start, its not running on all 4.
Edit: Wait a minute, I just read your last thread...take it to a mechanic, theres something not right there. Does it use coolant?
Postby Bling » Sat Mar 19, 2011 5:22 pm
+1 for the above
Unless you're trying to kill it 8O
Postby KIPH8N » Sun Mar 20, 2011 12:55 am
Dell'Orto wrote:Check your plugs for a start, its not running on all 4.
il change the plugs tomorrow.
nah its not using coolant bt i think theres a leak in radiator..
KIPH8N
Postby KIPH8N » Fri Mar 25, 2011 7:51 pm
Changed spark plugs seems to be idleing fine now thanks guys.
Has other problems too.
Video up.
Its pissing me off. :(
KIPH8N
Postby Bling » Fri Mar 25, 2011 9:13 pm
Looks perfectly fine to me.
If it was a steam train.
You bothered to get it checked by a mechanic yet or nah?
Postby KIPH8N » Fri Mar 25, 2011 9:18 pm
BZG|Bling wrote:Looks perfectly fine to me.
haha yeah i did
he said rebuilt the engine can be your piston rings or valve seal im goning to do a compression test soon.
The car has done 180000kms.
Can it be the supercharger seal. Its boosting 8psi standard is that normal?
KIPH8N
Postby Dell'Orto » Fri Mar 25, 2011 9:27 pm
BHG
Postby evil_si » Fri Mar 25, 2011 10:02 pm
What is the oil level in the s/c like? It doesnt hold much so generally if a seal goes the s/c goes pffft
Its not like a turbo with a constant oil feed.
You say there is a leak in the radiator, can you see the leak? How often do you have to top it up
my guess is you have cooked it
Also
That squeal sounds nasty, like a failed s/c clutch or tensioner bearing
evil_si
Postby KIPH8N » Fri Mar 25, 2011 11:33 pm
evil_si wrote:What is the oil level in the s/c like? It doesnt hold much so generally if a seal goes the s/c goes pffft
Also
i will check the oil in supercharger tomorrow..
radiator its just driping a little bit from the bottom plug, put when i start in up somthing leaks behind the engine i think its the water pump. i always have water in the reserve tank.
the squeal sound is from the power steering pump it locks up at times. going to replace it soon.
KIPH8N
Postby cozmoid » Sat Mar 26, 2011 9:20 pm
Having water in the reserve tank does not mean your radiator is always full. Actually check the radiator, you seem to have a few nasty problems that all point towards rooted engine.
Sorry bro but find a good mechanic you trust and open your wallet
Ae70/Te71 Hybrid
viewtopic.php?t=54364
cozmoid
Postby KIPH8N » Sun Mar 27, 2011 3:20 am
cozmoid wrote:Having water in the reserve tank does not mean your radiator is always full. Actually check the radiator, you seem to have a few nasty problems that all point towards rooted engine.
I shall update this tomorrow.
Roughly how much would be for parts to rebuilt the head including gaskits and piston rings?
If it was supercharger seal would it blow white smoke?
Will it still be boosting. Its boosting 8psi now.
KIPH8N
Postby cozmoid » Sun Mar 27, 2011 11:35 am
If it was the supercharger seal it would have killed the charger very quickly. They are a sealed unit and don't hold much more than a teaspoon of oil. If it's still boosting then it won't be the charger. You will be looking at 1k at least to rebuild and that's if the labour is mates rates. My cousin is a engine builder and he does a lot of 4a's for mates at around this price depending on parts and machine work. Make sure you get it checked by a actual engine builder not a general mechanic. A lot of, general mechanics will put it in the too hard basket and send it to a engine builder anyway and charge you 20% markup. A engine builder should be able to give you a definate diagnosis too.
Ae70/Te71 Hybrid
cozmoid
Postby Vertigo » Mon Mar 28, 2011 6:52 am
Dell'Orto wrote:BHG
TVIS just kicked in, yo!
Vertigo
Postby KIPH8N » Tue Apr 12, 2011 10:54 pm
I took it to mechanic they said just replace the engine.
From the guy i bought it from said it has a stuck vavlve.
Well i searched on the net right now.
The cars intercooler piping has oil inside it.
The car has rough idle.
It stalls sometimes.
And yes it blows blue smoke like alot of it.
Smells like its running rich.
It could b a pcv valve. Its got all the symptoms of it.
Could anyone tell me where this pcc valve is located on a 4agze engine. And where i could gt it from.
KIPH8N
