Mr Revhead wrote:
Btw your avatar looks a little odd....
Like a penis? Yeah now that you mention it...
For the idle problem, is it AFM and has it been tampered with? If so that might be the cause. Other wise you can try cleaning it.
Dell'Orto wrote:Check your plugs for a start, its not running on all 4.
Edit: Wait a minute, I just read your last thread...take it to a mechanic, theres something not right there. Does it use coolant?
BZG|Bling wrote:Looks perfectly fine to me.
If it was a steam train.
You bothered to get it checked by a mechanic yet or nah?
evil_si wrote:What is the oil level in the s/c like? It doesnt hold much so generally if a seal goes the s/c goes pffft
Its not like a turbo with a constant oil feed.
You say there is a leak in the radiator, can you see the leak? How often do you have to top it up
my guess is you have cooked it
Also
That squeal sounds nasty, like a failed s/c clutch or tensioner bearing
cozmoid wrote:Having water in the reserve tank does not mean your radiator is always full. Actually check the radiator, you seem to have a few nasty problems that all point towards rooted engine.
Sorry bro but find a good mechanic you trust and open your wallet
