Oil/Filter Change - Auckland
Postby Subway » Sat Apr 02, 2011 5:33 pm
I know its one of the most simple pieces of maintenance that I always do on my old cars, but....
On my new AS200 Altezza/IS200 it took me long enough to find the damn oil filter, let alone attempt to get at it (its under the intake manifold)
which means I either need to put it on a lift of some sort, or hydraulic jack and axle stands (of which I have neither), is there anyone in East Auckland that has a lift/hydraulic jack/axle stands that I could borrow for 20mins? its such a quick job, yet they put the filter in the most inaccessible place on the block.
Else, whats an oil/filter change worth at a half decent workshop....
Subway
Postby tsoob » Sat Apr 02, 2011 5:46 pm
79 bucks man drop by sometime
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Subway » Sat Apr 02, 2011 5:49 pm
tsoob wrote:79 bucks man drop by sometime
Have you seen where the filter is nick??? I wouldnt want to give you such a shitty job, seriously, the toyota engineers must have been smoking some really funky crack when they decided to put it there.
Could be time for an epic service though, I need those front tyres done as well haha
Subway
Postby allencr » Sat Apr 02, 2011 6:52 pm
Drive it up on a couple of blocks or just up on one side, have it leaning towards the drain plug. Chock the wheels.
SHAKE THE SHIT OUT OF IT. If it don't fall it ain't going to.
Drain it. Let it cool down so you can get to the filter without getting burned.
Use a good filter wrench. There's got to be one that will access & grip well.
If the new filter has the rubber flap/anti-drainback, pre-fill it a bit or crank without the EFI fuse to save the bearings from a dry startup.
Also, changing the filter for every oil change or even every 2nd time isn't a necessity.
allencr
Postby AE82 FXGT » Sun Apr 03, 2011 12:24 am
It'll probably be easier to get to it when it's on a hoist.
Also changing an oil filter is easy, why wouldn't you do it every oil change?
AE82 FXGT
Postby BZG Wagon » Sun Apr 03, 2011 5:42 pm
The filter on my GF's maz is under the air intake on the back of the engine. The only way to get at it with a decent grip is from under the car, with an arm either side of the exhaust.
I loosen the filter when the car is cold until the face is only just making contact. Then run it down to the shops and back, put some engine flush in it and it's pretty easy to get it off then.
If it's really, really difficult then you could look at a relocation kit for $300-ish?
BZG Wagon
Postby Brawler » Sun Apr 03, 2011 6:02 pm
Buy an oil filter relocation kit, then you will never have to worry about this problem again
zing! Sig got nuked. Sorry bout that.
Brawler
Postby Bling » Sun Apr 03, 2011 7:23 pm
A teaspoon of cement is a lot cheaper.... it doesn't hurt THAT much :lol:
Postby DeeCee » Sun Apr 03, 2011 7:45 pm
gen2 3sge had the oil filter under the mani as well. Pay tsoob to chuck in a relocation kit at the same time as the oil/filter change and you'll be gravy
GT Four Adovansu
DeeCee
Postby Bazda » Mon Apr 04, 2011 11:06 am
ALOT of cars have them under the intake manifold by the fire wall side.
Not hard to get to at all. But yes you do need a hoist or jack the front up on axle stands.
Users browsing this forum: Bing [Bot], Google [Bot] and 19 guests
