Will a 2JZ-GTE non vvt fuel rail adapter fit 1JZ-GTE +more Q
Postby mikeBrotherd » Mon May 02, 2011 7:10 pm
Im fitting an after-market fuel pressure reg (one of the D1-Spec 850hp type) and cant find a fuel rail adapter that screws into the end of the 1jz-gte fuel rail. But i can find heaps for the 2jz-gte. I would prefer to get away from using the factory reg inline if i can.
Could i use a 2jz-gte fuel rail adapter in my 1jz-gte non-vvt engine? Or is there a kit anyone knows of to suit 1jz? I have been looking at getting a Tomei 2jz-gte adapter but need to know it'll fit before i buy.
Also does anyone know the factory base or ideal fuel pressure for a 1jz-gte non-vvt? The engine has 3" y-pipes/exhaust and plan on running around 15~16psi from the factory twins.
Cheers in advance :-)
    JZS147 Aristo, 2JZ-GE
    KE70 Corolla Wagon, 4K, 5spd Man
    JZA70 Supra, 2JZ-GTE, Man, TurboR
    GA60 Supra, 1G-E
mikeBrotherd
Postby Mr Ree » Tue May 03, 2011 11:35 am
Why are you wanting to fit an FPR? I see you are sticking with the twins so it seems like an unecessary upgrade, unless Im missing something.
The toyota one does a great job without the need for lots of cost spent on fittings and pipe etc.
wak thud gush!
Mr Ree
Postby mikeBrotherd » Tue May 03, 2011 10:37 pm
future single turbo down the track...plus somethings up with my factory unit, has a unstable fuel pressure. Have checked for leaks and replaced hoses, have a walbro pump fitted so i put it down to fuel press reg.
    GA60 Supra, 1G-E
mikeBrotherd
Postby DFECTED » Wed May 04, 2011 11:01 am
ijzgte and 2jzgte fuel rails are different for different injectors. I just bought a banjo bolt and fitting from enzed and tapped that thread into the fuel rail
DFECTED
