leaking 4age sump
leaking 4age sump
Postby bluemaumau » Fri May 13, 2011 3:06 pm
ive redone my sump 3 times no to no avail.
the last time i did i took my time and did everything i knew to stop it.
*lightly sanded all surfaces
*torqued bolts and nuts to spec torque
*hammered surfaces of sump and baffle plate flat.
*used generous amounts of sealant.
can anyone see anything wrong with what im doing, or something im missing?
if not i think the issue may be do with the baffle plate being not flat, what is the purpose of this? -does it prevent oil surge onto the crank?
would it be unwise to remove it?
it seems like just having a sump and block would make things alot easier.
thanks
Postby Mr Revhead » Fri May 13, 2011 4:16 pm
Yes, its a windage tray.
can you see exactly where it's leaking? not actually another leak it is?
Is it maybe cracked?
Postby bluemaumau » Fri May 13, 2011 4:50 pm
3 points, on all sides around the deeper pick up end. dont think its cracked thinks it must just be out of shape...
whats the best way to get it all square again?
Postby Mr Revhead » Fri May 13, 2011 4:53 pm
Try a big sheet of sand paper, maybe glue it to a plank.
put the sump on it and sand away for a little.
Then take a look, should expose high points so you can see whats up. I would have thought though that any gap not able to be filled with a good sealant (using a good one?) would be easy to spot by eye.
just as long as you are sure it's not the front crank seal or anything leaking down on to it.
Postby Boost_4_Life » Fri May 13, 2011 5:29 pm
I have the same problem its a nightmare. To be fair my sump probably wasnt that flat tho. Seems finicky to get right...
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby matt dunn » Fri May 13, 2011 8:12 pm
What are you using to seal it?
TGP stuff or something else?
Postby evil_si » Sat May 14, 2011 9:39 am
Are you leaving the silicone as a bead or smearing it out with your finger?
I always find it best to leaveit as a bead, and to much siliconis a bad idea, it oozes out into the sump, and gets jammed against the suction strainer, if not sucked thru the oil pump
evil_si
Postby Lloyd » Sat May 14, 2011 10:27 am
As said above, use a decent sealer. The best I've come across so far is Nissan stuff to be honest
Postby Mr Revhead » Sat May 14, 2011 10:28 am
We need to do a test between that Nissan stuff, 3 Bond and the Toyota stuff!
At Toyota we used to sell it to other dealers! And where I am now, they all swear by 3 Bond
Postby Dell'Orto » Sat May 14, 2011 12:11 pm
Yep, big fan of 3Bond...spendy shit, but works good. Never tried the Toyota one, is it available by itself?
Postby 1I1 » Sat May 14, 2011 12:50 pm
Sure is.
About $150 rrp for a 100g tube
TRD Clicky >>Here
1I1
Postby Mr Revhead » Sat May 14, 2011 12:55 pm
Whoa! Shot up in price! Used to be like $50-60!
Postby 1I1 » Sat May 14, 2011 12:59 pm
The black stuff (blue box)?
Ha yeah it's not cheap! We use alot of Wurth's black sealant - about $20-$30 a tube and does the job
TRD Clicky >>Here
1I1
Postby rollaholic » Sat May 14, 2011 3:08 pm
three bond 4 lyfe
Postby RedMist » Sat May 14, 2011 3:36 pm
Another vote for 3 bond. Amazing stuff.
The price certainly teaches you to squeeze from the bottom of the tube.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby rollaholic » Sat May 14, 2011 6:40 pm
haha, sure does. i cut em open and scrape out every last drop
Re: leaking 4age sump
Postby allencr » Sat May 14, 2011 7:43 pm
bluemaumau wrote:ive redone my sump 3 times no to no avail.
Even though it seems to be easier to diagnose a leaking sump then to seal it, I think the opposite is true.
Sorry, but sure it's the sump?
allencr
Postby XSVWGN » Sun May 15, 2011 1:46 am
I removed my sump twice to fix my leaks. one leak was slowly squirting oil onto the heat wrap of the dump pipe making a big smokey mess. I actually bent the edges up in certain areas and had a good bead of gasket goo and now it works a treat as everything is flat!!!
Matt
2008 Kia rio - work car
XSVWGN
Postby bluemaumau » Sun May 15, 2011 11:01 am
99%its the sump. the engine is brand new(new seals everywhere) less than 1400kms
and the oil isnt above the sump.
just using a silicone sealant from repco. - cant remember brand or name.
maybe ill try the 3 bond.
good idea revhead .
although ud think if it was 1-2mm out that the sealant would plug that gap- maybe its just the pressure :?
and yes leaving it as a bead.
im putting a bead around windage tray and sump.
Postby sergei » Sun May 15, 2011 11:22 am
If there is excessive pressure in the sump, it means your PCV system does not work or there is too much blow by.
Users browsing this forum: No registered users and 33 guests
