Leaking Brake master cylinder?!
Postby Adoom » Fri May 13, 2011 3:01 pm
Failed a WOF on a "leaking" brake master cylinder.
Apparently it's leaking from the back of the cylinder where it mounts to the servo.
I had a look at lunch and there is excess fluid, on the reservoir from spillage or something. And there does look to be some running down the servo.
I still need to pull it off and see where it's actually coming from.
It's a 1993 AE100 with 150000km. WTF?! The seals have $&#$% out already?! :evil:
Adoom
Postby Dell'Orto » Fri May 13, 2011 3:18 pm
Yeah, has probably sat for long periods of time given its k's and age.
Postby Quint » Fri May 13, 2011 3:48 pm
I've found that my older cars after leaving them to sit for ~6months when I've come back cylinders are leaking. Rust causes pitting which then chops your seals, sux big time.
Quint
Postby CAMB01 » Fri May 13, 2011 11:42 pm
Brake fluid is hydroscopic. So it absorbs moisture that can eventually over time start to damage the seals and cause leakages, if the fluid isn't regularly changed.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Adoom » Sat May 14, 2011 11:43 am
Quint wrote:I've found that my older cars after leaving them to sit for ~6months when I've come back cylinders are leaking. Rust causes pitting which then chops your seals, sux big time.
It's an alloy cylinder, so no rust. But yeh, it may have been sitting for a long time before I got it.
PITA for the daily though.
Now, do I get a replacement from pick a part? Or get a seal kit and rebuild it? Bearing in mind this is the CHEAP daily.
Adoom
Postby Lloyd » Sat May 14, 2011 11:58 am
Pick a part one.... that wont have been sitting around either
Price a new one, they're often not too bad
Postby Dell'Orto » Sat May 14, 2011 12:02 pm
Seal kits are cheap as hell
Postby amdeman » Sat May 14, 2011 1:41 pm
Dell'Orto wrote:Seal kits are cheap as hell
Where would be the best place to source a kit?
amdeman
Postby Adoom » Sat May 14, 2011 4:09 pm
I'd use MP Autoparts because they are local to me. But BNT would probably do it too.
Adoom
Postby Dell'Orto » Sat May 14, 2011 5:49 pm
Toyota, BNT, Autostop, most brake specialists.
Postby Bling » Sat May 14, 2011 6:31 pm
Could just price up a rebuild of it with new seals with a brake specialist. I got my callipers done ages ago and it was pretty reasonable. Good peace of mind too.
Postby Brawler » Sat May 14, 2011 6:42 pm
This year i got my DD celica, was sitting for 4 years, the master cylinder $&#$% out after a week of driving lol
zing! Sig got nuked. Sorry bout that.
Brawler
Postby amdeman » Sat May 14, 2011 8:20 pm
Sweet, thank you.
Will be visiting one of these places soon enough.
amdeman
Postby Adoom » Sun May 15, 2011 3:37 pm
Used some brake system cleaner to spray off all the spillage around the master cylinder yesterday. Took the master cylinder off today. It was pristine in there, no signs of brake fluid seepage. I think it just looked like a leak and it was just spillage.
YAY! :D
Adoom
Users browsing this forum: Bing [Bot] and 23 guests
