Help me kill the beeps!
Postby peas » Sat May 21, 2011 4:03 pm
Hey all. Just got a GT Caldina which seems to insist on telling me that the keys are in the ignition, the drivers door is open, the ignition is on etc. You know the annoying little beeps, buzzers alarms etc. So I want to get rid of them, I think it is somewhere in the jungle that is below the fusebox but can't see much there that looks like it would be making the noise... Anyone know exactly where to find the culprit?
'97 Caldina GT (ST215G)
peas
Postby h8wrxs » Sat May 21, 2011 4:11 pm
just try pulling each fuse out one by one until you kill the beeps?
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby Rick » Sat May 21, 2011 4:17 pm
I found on my Trueno I only disconnected the switch which is operated by the key, I simply unplugged it on the ignition barrel and it got rid of those annoying beeps.
Postby peas » Sat May 21, 2011 4:30 pm
That might do it too... will invert myself later under the dash and see what I can disconnect. Makes you wonder just how retarded Toyota thinks we are?!
peas
Postby Bling » Sat May 21, 2011 5:15 pm
You have seen how dumb society is becoming aye? Nothing surprises me :lol:
Postby FST4RD » Sat May 21, 2011 5:19 pm
My old Starion had a box under the seat with a switch, flick that and got rid of the beaps.
Problem is that I left the lights going one night and flattened the battery and locked the keys in the car.
Switched it back on after that! :lol:
1983 Mitsubishi Starion
1995 Subaru legacy GT SW
FST4RD
Postby sergei » Sat May 21, 2011 7:52 pm
If you disconnect the switch on the ignition barrel, the light warning beep will still be functioning (which is good).
Postby BZG Wagon » Sat May 21, 2011 8:05 pm
Why not find the speaker and kill it?
I HATE the seatbelt buzzers they have on newer cars.
BZG Wagon
Postby snwtoy » Sat May 21, 2011 8:10 pm
I've had my caldina for a loooong time, the car hardly ever beeps?
snwtoy
Postby matt dunn » Sat May 21, 2011 8:22 pm
Rick wrote:I found on my Trueno I only disconnected the switch which is operated by the key, I simply unplugged it on the ignition barrel and it got rid of those annoying beeps.
That is the best way,
as it is really easy to do,
It is really easy to undo,
it doesn't affect the normal headlight beeper.
Postby Vertigo » Sat May 21, 2011 8:36 pm
all these useless beepers, and yet i havent seen one that beeps when your engines starting to overheat.. or when oil pressure drops..
TVIS just kicked in, yo!
Vertigo
Postby Snaps » Sat May 21, 2011 10:16 pm
Vertigo wrote:all these useless beepers, and yet i havent seen one that beeps when your engines starting to overheat.. or when oil pressure drops..
Maybe the engine manufacturers don't expect this to happen to thier engines? :lol:
But they can completely see Joe Public leaving thier door open, lights on, or seatbelt unbuckled. :lol:
Cheers,
Brandon
Snaps
Postby ch4ng » Sat May 21, 2011 10:24 pm
Vertigo wrote:one that beeps when your engines starting to overheat.. or when oil pressure drops..
Such a good idea, especially when so many people only occasionally look at their dash to see if they're speeding
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
Postby matt dunn » Sat May 21, 2011 10:41 pm
Snaps wrote:Maybe the engine manufacturers don't expect this to happen to thier engines? :lol:
And flat batteries on new cars cause issues with grumpy customers,
even when it's is the customer's fault.
Been to a few cars now where the customer blames the brand new battery we sold them last week as being faulty,
but as soon as you connect the jumper leads the headlights come on...........
Postby peas » Mon May 23, 2011 5:56 pm
Sweet job done tonight after work. Took all of 3 minutes!
Retards... glad to be out of retail!
peas
Postby Malcolm » Mon May 23, 2011 6:28 pm
you should confirm what you did and how you did it for others' future reference
Postby peas » Mon May 23, 2011 11:17 pm
Smart idea...
Simply removed the two screws on either side of the steering wheel on the steering column shroud and the one underneath. Pop the lower half of the shroud off and have a look at the ignition barrel. There are two plugs, one with 8 or so wires and one with 4. Unplug the one with 4 wires which is closest to the end of the barrel and reassemble the column shroud.
Beeps stopped :D
peas
