Brand new BC's are about $1400NZ for a set in NZ. Would save a lot of messing about.toyotaspeed wrote:haha SS adjustables are far more expensive than what i have purchased. Very hard to come by also. So it seems kind of sensilble to me to save money and time
The conversion is a simple swap over process, during the conversion, you can choose to upgrade and customise some parts, and I will post further information on that.
here's a short list of parts thats required:
struts
MS hubs (ABS) - Best to change the wheel bearings while you're at it
MS lower ball joint- usually already connected to the hub when you get a used hub
lower control arm
sway bar
MS sway bar brackets and bushes
sway bar links- new items preferred
inner and outer tie rods - new items preferred, replace dust boot if the old one's ripped, toyota genuine boot is the best here
Single pot brake caliper
MS brake disc
MS brake line
You can retain SS abs sensor and cable, I got brackets welded on the chassis and the strut. You could cable tie it too, they do wonders.
Subframe is identical between the two, drive shafts will fit fine on the MS hub but make sure you get the ABS hubs if you want to retain ABS, you could also retain the superstrut steering rack, but both inner and outer tie rods need to be changed to the straight MS ones.
The SS sway bar brackets MAY work with the MS sway bar, it bolted on fine on some conversions, but didnt work on some others such as my car. You could however modify the bracket to fit by simply cutting off a ridge.
With all the parts and correct tools on hand, this conversion should be quite straight forward and shouldnt take too long.
Bazda wrote:Since when did BC make superstrut coilovers for the corolla??
I know they make them for a Celica... not sure if they are the same. But it requires cutting up the stock strut leg and welding it to the coilover :S
If you go to pick apart you can prob buy all those bits for the conversion for around $150
