Suggestions on change of suspension, brake disk
Postby Tagged » Fri Jun 03, 2011 10:35 pm
My tyre got punctured today by a bolt....wtf....so I took the car to Tyres2Go in chch and did a test after the tyres are changed. This is the result
sorry image a bit big due to the small words
I know that my disk needs changing soon, this could also be responsible for the rolling resistance, but could there be any other reasons for the problem?
What can I do to fix ovality? New rims??
And it says my rear suspension only have %50+ left and needs to be replaced very soon. What does this involve?
Btw the guy in the shop told me that the strud in my BZR is just a normal strud, common in any other cars.....although im pretty sure its a superstrud tho.....anyway I can confirm this myself?
Tagged
Postby Dell'Orto » Fri Jun 03, 2011 11:49 pm
Does it have a sticker saying superstrut suspension? Does it has a funny looking strut with a long leg coming off it or does the hub bolt directly to the strut?
Ovality is likely just tyres out of balance, I take it thats from one of the drive on type testers?
Postby Tagged » Sat Jun 04, 2011 12:01 am
Dell'Orto wrote:Does it have a sticker saying superstrut suspension? Does it has a funny looking strut with a long leg coming off it or does the hub bolt directly to the strut?
nope doesn't have stickers. Oh yea I should go look for that long funny looking leg haha. Will check tmr. And yea its one of those "roller in the ground" machine test
Tagged
Re: Suggestions on change of suspension, brake disk
Postby allencr » Sat Jun 04, 2011 8:27 am
Tagged wrote:I know that my disk needs changing soon, this could also be responsible for the rolling resistance, but could there be any other reasons for the problem?
No, the brake disk doesn't need changing soon and it is not responsible.
A dragging caliper, piston and/or slide, or under inflated tire is it, the bearing is very unlikely. Also the toe-in is way off and IMO is the biggest cause, after stuck brake/s & low pressure.
Very cute picture. It looks biased towards profits rather then safety & performance. Is the ovality off on the new tire/s?
allencr
Postby Lloyd » Sat Jun 04, 2011 12:43 pm
allencr wrote: It looks biased towards profits rather then safety & performance.
My thoughts too
Postby BZG Wagon » Sat Jun 04, 2011 1:07 pm
Dude that looks seriously bad and really unsafe.
You're going to need a complete overhaul with slotted rotors, bigger brake callipers, new pads, height adjustable suspension and some new 18"s to fix the ovality.
At least that's what I'd be telling your wife / partner
BZG Wagon
Postby amdeman » Sat Jun 04, 2011 1:08 pm
My thoughts too
Great money making venture.
amdeman
Postby Mr Revhead » Sat Jun 04, 2011 3:36 pm
wtf
8 and 11mm of toe in?!
Postby Bling » Sat Jun 04, 2011 3:53 pm
It's mm/m though, wtf is a slip test? :lol:
Postby Mr Revhead » Sat Jun 04, 2011 3:54 pm
True... I read that totally wrong lol
Postby Dell'Orto » Sat Jun 04, 2011 7:59 pm
My thoughts too
Has to be, those machines are like $40k :lol:
Postby Tagged » Sat Jun 04, 2011 11:41 pm
Thanks to all for your replies!!
@allencer, sorry I wasn't clear on the disks. I've got them checked at magoos a while ago and the measurements came out under. I was also told that the disks might have sheered therefore causing rolling resistance.
I've also had my alignment done about 3 or 4 months ago I think. Do they go off that fast?? Or could they have given me a false measurement to have me done the alignment with them?
and yes I feel the same way towards to bias....strongly...
also I've got a seemingly stupid question here....Does BZR's come with all round superstruts? Or just front superstruts with normal rear suspensions?
Thanks guys
Tagged
Postby Boosted_162 » Sun Jun 05, 2011 12:03 am
Superstrut is front only. Always macpherson strut in the rear. And allignment doesnt usually go out that fast, unless you have done something to put it out ie hit a big pothole etc
Postby Tagged » Sun Jun 05, 2011 12:28 am
Boosted_162 wrote:Superstrut is front only. Always macpherson strut in the rear. And allignment doesnt usually go out that fast, unless you have done something to put it out ie hit a big pothole etc
I see, thanks man!
Tagged
Postby touge_ae101 » Sun Jun 05, 2011 4:27 am
that looks like a printout to generate BS/revenue by telling you a whole heap of shit that doesn't mean anything and they will say "we will fix it for you it will cost $$$"
tbh go to a tyre/alignment shop you can trust and who you know are GC's. they will tell you if you need to change anything and will be trying to help you rather than just make money from you.
none of that info means shit in the real world except possibly the toe info. but a tape measure/looking at it by eye would also tell you that. brakes are easy to fix - new pads and fluid, good bleed etc. 1-2 hours work.
touge_ae101
Postby darkwolf » Sun Jun 05, 2011 12:06 pm
Try places such as Midas where they do free brake checks. If there is an issue they'll let you know. Certainly more than the typical tyre and other repair shop where they'll tell you there are issues for the sake of revenue.
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Postby rollaholic » Sun Jun 05, 2011 12:19 pm
yeah, places offering free checks are doing it to generate revenue too.
find a place or person you trust, and take their advice is all i can say. if you post up what area you are in, someone is bound to have a recommendation.
