Bonnet wont open
Bonnet wont open
Postby MetalupYoAss » Sat Jun 04, 2011 4:03 pm
Hi, Ive had this problem on a couple of older toyotas, when you pull the lever inside the car to open the bonnet it doesnt click up like it should, the only way to open it is to hold the lever and have someone else pull the bonnet up.. annoying
Im sure other people have this problem too, I've tried putting crc in the mechanism, and ive checked that the cable is pulling all the way back but it still dosent help..
MetalupYoAss
Postby Alex B » Sat Jun 04, 2011 4:09 pm
Hold leaver out, smack back corner of bonnet while holding leaver, profit.
Postby rollaholic » Sat Jun 04, 2011 5:29 pm
wedge a pry bar under the bonnet, pull lever. the weight of the bar will pop the bonnet open for you
Postby Bling » Sat Jun 04, 2011 6:32 pm
Try adjusting the location of the latch behind the grill.
Postby AJz » Sat Jun 04, 2011 6:47 pm
Alex B wrote:Hold leaver out, smack back corner of bonnet while holding leaver, profit.
works like a charm
I had vtax :(
AJz
Postby MetalupYoAss » Sun Jun 05, 2011 11:58 am
Sensible suggestions only thanks guys...
MetalupYoAss
Postby rollaholic » Sun Jun 05, 2011 12:21 pm
who didnt make a sensible suggestion? we've all given you a way to open to bonnet by yourself, and best of all, none of them cost any money!
Postby Jdawg » Sun Jun 05, 2011 12:29 pm
Have you tried adjusting it. All bonnet catches I have seen have some form of adjustment. Either the mounting plate can be moved or the spring on the catch can be wound in/out/replaced with old valve spring
Jdawg
Postby Boosted_162 » Sun Jun 05, 2011 1:26 pm
Jdawg wrote:Have you tried adjusting it. All bonnet catches I have seen have some form of adjustment. Either the mounting plate can be moved or the spring on the catch can be wound in/out/replaced with old valve spring
Or sometimes have rubber stops mounted on the car to hold the bonnet away, and these can usually be wound out. Sometimes winding these out will push the bonnet up enough for the catch to work properly (if that made any sense at all :lol:)
Postby iOnic » Sun Jun 05, 2011 7:01 pm
Yeah adjust the rubber stops to preload the bonnet catch. Sometimes you can add washers to make them taller.
Postby h8wrxs » Sun Jun 05, 2011 7:05 pm
remove bonnet catch completely, install bonnet pins, wear flat-peak cap sideways, talk like 50 cent.
problem solved
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby Mr Revhead » Sun Jun 05, 2011 7:06 pm
^ illegal :P
Postby bluemaumau » Mon Jun 06, 2011 1:18 am
is it
i have no catch and pins?
(radiator in the way now)
dont have flat peak with shiny sticker or 50 cent accent though/
car got vtnz wof and cert
Postby KwS » Mon Jun 06, 2011 1:27 am
had a couple of cars do this. Basically hosed the shit out of the catch with CRC. used a screw driver to "close" the bonnet a few times, made sure it was well lubricated. Bonnet worked fine since.
KwS
Postby Jdawg » Mon Jun 06, 2011 11:02 am
Mr Revhead wrote:^ illegal :P
Which part is illegal
Fitting of hood pins is legal.
Removing the catch may be considered part of Frontal impact component which means it has to stay
Unsure about these 2: wear flat-peak cap sideways, talk like 50 cent.
Jdawg
Postby iOnic » Mon Jun 06, 2011 11:08 am
Yeah nothing illegal about fitting bonnet pins. Just need to retain the secondary catch (lever you pull up when you go to lift your bonnet) so that the bonnet doesn't fly open in the unlikely event that the pins fail - I don't think that's a legal requirement, more a common sense thing. Fitted bonnet pins and removed factory catches on more cars than I can remember and never had a problem at Cert/WOF time.
Postby Mr Revhead » Mon Jun 06, 2011 11:18 am
I was fairly sure you required a secondary catch.
Postby iOnic » Mon Jun 06, 2011 11:22 am
Yeah I've always assumed so but more out of common sense than having seen an actual legal requirement anywhere. Kinda curious now :lol:
Postby MetalupYoAss » Mon Jun 06, 2011 9:32 pm
thanks to those with helpful advice.
If i wanted bonnet pins i would have found an install tutorial in youtube
the rest of you immature fanboy poster fags.. toyspeed wouldnt be what it is without you guys, keep it up!!
MetalupYoAss
Postby ch4ng » Mon Jun 06, 2011 10:28 pm
*half serious question* Regarding the "Secondary catch" would the second bonnet pin on the other corner of the bonnet count?
Chondah Civic
2T Navara
ex:
Charade Detomaso
MX5 - Stancemobile
MX5 turbo - El Tigre
87 Alto - The Tragic 3cyl powah
AE111 BZ-G Death Race 15.09
No Limits Onsite Paint Repairs. Cut and polishing, stone chip and scratch repairs. 021-177-8539 Mention Toyspeed.
ch4ng
