SR20 help
SR20 help
Postby groupagt4 » Fri Jun 10, 2011 4:58 pm
Hi guys
Got a sr20de powered s14(manual). It keeps on dropping revs and dying when i come to a standstill. It runs fine under normal driving conditions, just dies as soon as I come to an intersection. I have checked the battery and alternater and they are both fine, any idea what it could be?
groupagt4
Postby gt4dude » Fri Jun 10, 2011 5:34 pm
Vac leak? Idle control valve problem?? AFM problem?
セリカGT-FOUR ST205 中期型 (Chuuki)
200AWKW / 370NM
gt4dude
Postby groupagt4 » Fri Jun 10, 2011 5:44 pm
yea not sure, maybe vac leak. Would the other two throw a engine check light?
groupagt4
Postby RS13 » Fri Jun 10, 2011 7:30 pm
I know I sound like a broken record with this, but have you run diagnostics?
RS13
Postby DRFTIN » Fri Jun 10, 2011 11:18 pm
does it backfire on gear shifts? mine is doing the stalling thing as well and i cant work out what it is. seems like a vacuum thing to me but no leaks i can find
DRFTIN
Postby groupagt4 » Sat Jun 11, 2011 1:38 pm
Not sure how to run the diagnostics. I have tried to do a bit of research but cant figure it out. It doesnt backfire or anything, just dies. It has a stupid aftermarket intake pipe and pod. There is a pipe coming from the cam cover that looks like it goes to the factory intake pipe, in this case it is just blocked off, could it be this?
groupagt4
Postby ALES_AE111 » Mon Jun 13, 2011 5:16 pm
Hi mate,
I had the same issue in my old SR20 sentra. Kept stalling at inconvenient times and made traffic a real nightmare. I was advised that the O2 sensor was stuffed but didn't have a chance to test that out as the car caught fire.
Maybe a place to start? Mine was also running pretty rich and not very efficiently.
ALES_AE111
Postby RS13 » Mon Jun 13, 2011 5:53 pm
RS13
Postby CelicaGT8 » Mon Jun 13, 2011 7:46 pm
BOV
CelicaGT8
Postby tuff86 » Mon Jun 13, 2011 7:49 pm
de is non turbo, sounds like inlet manifold leak...
Current: AE86 Corolla GT, Hyundai Veloster Turbo & Santa Fe
Previous: Lots of Toyotas and a few others
tuff86
Postby petrolhead » Mon Jun 13, 2011 9:41 pm
I have found this on quite a few cars i have driven with SR engines. Maybe stretched cam-chain kicking out cam angle sensor?
Hewies
Race and Restoration
petrolhead
Postby 3T-Rona » Tue Jun 14, 2011 1:27 pm
try cleaning out the throttle body
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby Adamal » Tue Jun 14, 2011 2:38 pm
And give the AFM a good clean with some Co-contact cleaner. Make sure the TPS plug is clean too.
I had an issue with it hunting and revving too high at warm idle with mine, but can't quite remember what I did to fix it.... But check those out.
