spark problem?
spark problem?
Postby TRD_ZERO » Sat Jun 11, 2011 12:43 pm
So i did some tuning for about an hour and a half and lost spark. Just wasnt getting any spark so i loaned a igniter and coil and have spark now but its red/orange. Isnt it supposed to be a blue spark? It doesnt want to idle now. Ideas?
Pro tip: use meaningful, specific subject headers
Previous:
TRD_ZERO
Postby QikStarlie » Sat Jun 11, 2011 7:57 pm
might help if you tell us what, ecu, coils, ignitor etc
might be a dwell issue
QikStarlie
Postby TRD_ZERO » Sun Jun 12, 2011 3:35 pm
Yeah ok. Im running a link g3 in a ae111 20v turbo. I had it running and was getting it tuned but then suddenly wouldnt start after tuning for an hour and a half. Found there was no spark coming from the coil. Recharged the battery the next day as it had gone flat. Thought that might be contributing to the problem. Once i put the battery in and checked for spark and was getting spark but it was a red/orange. Thought that was weird as the spark is usually blue/white. The tuner thinks its the igniter and coil. So borrowed a coil and igniter, swaped it over and was still getting a red spark. Tried to start the car and it just wont idle. So i think im still having problems with my spark. Any ideas?
Previous:
TRD_ZERO
Postby MAGN1T » Sun Jun 12, 2011 3:51 pm
It doesn't matter what colour the spark is, so long as there's a spark.
The colour will change with contaminants on the plug.
Probably your ECU got spiked and corrupted the memory.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Flannelman » Sun Jun 12, 2011 8:40 pm
What was the last thing you did before the ignition issue?
Flannelman
formerly known as Affroman
Postby QikStarlie » Sun Jun 12, 2011 9:02 pm
what are your dwell settings / i can check if you email me the pcl file
QikStarlie
