levinguy wrote:don't expect it to last 4 ages if you do. (see what i did there?)
there's not really any point in reving that high, pretty sure they don't make any more power up there.
sergei wrote:Revlimiter will prevent you going too high when accelerating. As long as you are not sitting on revlimiter you are fine. Just don't slam a gear too early when decelerating (thus forcing engine to do silly RPM) and you will be fine.
BZG|Bling wrote:........Make sure the oil is @ the full mark and you should be sweet. Always when engine is warmed up.
AE86less wrote:You may have noticed a small measuring device on your engine named a dipstick?
BZG|Bling wrote:I was going to mention not FULL as in to the top of the engine but didn't in the end. However, maybe I should actually mention it... do NOT fill it to the top!
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
