wobbly wrote:sweet, ok so all pipes have finally turned up, silicon hosing and pod filter plus the blow off valve, (all brand new and about $300) have notice that some pix on here have the bov vented back into intake pipe do i need to do this??
or weld anything to the intake pipe, air sensor,etc...?
Kiwi-Corolla wrote:All you have to do is cut a small hole in the pipe near the throttle body, to accommodate the rubber bung for the intake air temperature sensor. .
sergei wrote:Kiwi-Corolla wrote:All you have to do is cut a small hole in the pipe near the throttle body, to accommodate the rubber bung for the intake air temperature sensor. .
If standard air temp sensor was in the air box then it will need to go before turbo, between the air filter and turbo.
ROBODISCO_20v wrote:Has anyone got a DIY on installing a boost tap/controller in a ST215? A mate is wanting to hook on up on his GTT
ROBODISCO_20v wrote:It's running 25psi at the moment due to him playing around with it. He's a mechanic so if it goes pop it wont be to bigger issue.
Users browsing this forum: Bing [Bot] and 19 guests
