Grrrrrrr! wrote:depends what path you want to go down really.
if it more power for cheap then starting with a 4AGZE is possibly the best route, add manifold,turbo and ecu, done.
High revving NA power.. hmmm. both 16v and 20v have good parts supplies these days.
It also depends what you want to stick it in. FWD or RWD?
RedMist wrote:You haven't described your application or your budget, and I don't know what you're talking of with "workshop friendly mods". If you're talking about reducing power by using an aftermarket intake manifold, filter, then any of the 4a's will loose power through "workshop friendly mods"
20 valve is the cheapest power stock. Also the most costly to get big power from.
ZE will give you the most power with FI.
Smallport will give you the most power NA (with a tonne of development dollars thrown it's way).
Lloyd wrote:Just go smallport, easist option and a nicer engine if you're wanting driveability anyway
rollaholic wrote:quads dont fit at all, require work and money and an ECU to run properly, nevermind actual power gains.
sweet sound though.
standard blacktop is cool, or standard smallport. dollars per HP gained turbo is the only way.
20v exhaust manifold can be made to fit with minor alterations, looks better at least.
any meaningful increase of power in a small displacement NA engine typically means big cams, lots of compression and not much action below 6k rpm. stick with standard for 'driveability' and reliability.
TRDWGN wrote:the easiest option is to buy a silvertop donor car, find a tidy silvertop and you have a relatively simple drop in solution. Remember some of the issues you had on the wagon were because it was ae92 into ae101, if you keep it all 101 it will be almost plug n play
3sge would be cool but 2zzge would be betterAnd arguably a bit easier
iOnic wrote:Smallport is probably the best compromise of ease and drivability. But as said before it really comes down to what you actually want out of it. I dont think fitting an engine out of something else altogether fits in your definition of workshop friendly IMO. A 3S or 2ZZ isnt exactly a bolt on
BZG|Bling wrote:The guy who posted that video owns it.
Everything you're asking has been covered many many times. If you can't be bothered having a search around for the information I can't see any engine swap getting off the ground
