h8wrxs wrote:out of curiosity how did the gt28 go on a 4age? is it a good size for the 1600?
h8wrxs wrote:just sorting out the last btis and pieces i need before i go pulling my car apart and rebuild it as a 4agte
where do i run the water feed line for the turbo off my 20v silvertop?
im assuming the drain line ill just tap into the base of the radiator?
~SlideWays~ wrote:ball bearing core was toast after less than 10,000km
matt dunn wrote:~SlideWays~ wrote:ball bearing core was toast after less than 10,000km
From what we were told all Ball Bearing turbos must have water through them no matter what as there is something in the bearing part that is sensitive to temperature.
