strx7 wrote:3sge/3sgte cranks are forged, 3sfe cranks are cast
what about 5s cranks?
levinguy wrote:strx7 wrote:3sge/3sgte cranks are forged, 3sfe cranks are cast
Celica RA45 wrote:next you guys will saying i need to keep the altezza dual mass fly wheel .or the crank will break
and changing rod ratio will have no effect on the crank .it will only dwell at tdc longer same with bdc and it changes the piston speed down so i can rev it higher
Celica RA45 wrote:we are talking milli seconds
Celica RA45 wrote:look at it this short rod piston speed maxes out about 8000 rpm longer rods changes piston speed so can rev higher im talking about piston dwelling at top d c longer thats it
KinLoud wrote:Pulled a crank from a late model 5sfe - it was forged.
Ken
Akane wrote:
How do you know that it's forged? Not doubting you just want to know how you can tell, besides no casting marks
Malcolm wrote:Actually having a greater rod ratio reduces your peak accelerations, not your speeds
Increasing the rod ratio reduces the force due to acceleration on the crank, conrod and piston, it also reduces the angular displacement that the conrod moves through during a cycle which reduces side loadings on the piston/cylinder walls. Unfortunately this does come at the expense of a longer/heavier conrod.
MAGN1T wrote:Rod ratios is all bullshit, like lots of other things when it comes to cars, a compromise at best.
A longer rod puts less side loading on the cylinder walls, a shorter rod keeps the piston at TDC for less time supposedly reducing detonation or the effect of it.
It's just more money down the drain for no reason if you decide to change what you've got.
Steve
