Dell'Orto wrote:Cant really chip them as such, though some Japanese tuners added daughterboards with flashable ROMs. Piggyback or Link are the best options really.
amdeman wrote:Dell'Orto wrote:Cant really chip them as such, though some Japanese tuners added daughterboards with flashable ROMs. Piggyback or Link are the best options really.
So there are some daughter-board options?
Great, if that's the case!
Although a full Link, or similar standalone would be better.
What a about the likes of E-manage?
gt4dude wrote:What would you guys suggest in my case then, with
Gen 3 3S-GTE ST205
Standard ecu
Garrett GT28RS disco potato
factory fuelling system with factory 540cc injectors
Standard boost 14psi
at this level, the GT28RS runs very close to the standard CT20b turbo, aside from having awesome BB spoolup. The turbo is capable of running up around 20psi, the ECU is not.
So FCD & water injection? Or Link G4 plugin?
sergei wrote:[Third option:
Wire in motec and get somebody competent to set it up and tune, while maintaining as many factory options as possible.
Gen 3 3S-GTE ST205
Standard ecu
matt dunn wrote:sergei wrote:[Third option:
Why would that be any better than the latest G4?
sergei wrote:I I am not sure if Motec does that, but what I seen from demonstrations the configuration/tuning app is much more powerful.
sergei wrote:For example very simple thing like controlling water pump:
I want water pump for I/C to turn on for 1 min and off for 3 min unless full throttle then run full time. Can you do that with link? Nope, you need little black box to do that.
Why do I have to fill in the Aux input map for standard BOSCH temp sensor? Why only Temp inputs have preset for the temp senosr.
If you want an ECU that will handle occasional fill up with 95 while being tuned for 98 (in case of Jap import 100) your Link will not do that. It will happily knock your engine.
Will link self adjust for drifting senors? Nope. It does not have Fuel Trim adjustment based on sensors. So it will consume more fuel.
Users browsing this forum: Majestic-12 [Bot] and 10 guests
