RomanV wrote:Small secondary ratiator... Turn the heater on!
wde_bdy wrote:Maybe look for a heat exchanger from a water to air setup? Subaru/GT4 setup or similar would be more suitable than an oil cooler. Could also look at motorbike radiators.
Callum
Leon wrote:Is it a family thing to have cars that ought not be turbo'd, have turbo's fitted, and overheat?
If so, that'd be the strangest dna strand ever.
Mr Revhead wrote:Just askng, but have you got ducts/blanking plates around the rad to make sure all air entering the front actually goes through it and not around/over it?
~SlideWays~ wrote:Does anyone else in your family go through multiple cars like they're a hot potatoe?
Leon wrote:~SlideWays~ wrote:Does anyone else in your family go through multiple cars like they're a hot potatoe?
Not at this stage, as my half brother is only about 10, and my half sister is about 2.5. So, a bit young to be owning cars. Give it time.
~SlideWays~ wrote:RomanV wrote:Small secondary ratiator... Turn the heater on!
Lol yeah but you are generally asked to keep windows up so I'd be driving an oven.
Dell'Orto wrote:~SlideWays~ wrote:RomanV wrote:Small secondary ratiator... Turn the heater on!
Turn your old sunroof into a reverse scoop - profit?
gepsk8 wrote:best test as is at moment, with external oil cooler.
how old is radiator? could blocked up, maybe from new. alloy one tend have small fins to start with.
has your turbo got beanie on turbo, with heat warp on headers & down pipe pass sump?
have you go any pictures of set up?
have you tied divided plate between radiator location and turbo?
stop heat transferring to radiator (alloy radiators take ages cool down once they get hot)
if still have problems vent hole in bonnet behind radiator to let hot air out faster
Users browsing this forum: Bing [Bot] and 24 guests
