Top Mount secondary Radiator
Postby gepsk8 » Fri Jul 01, 2011 6:12 pm
Can you move intercooler to driverside more?
there wont be getting hell of lot fresh air get to radiator with intercooler being that thick dam.
Can move radiator out to passenger side more?
then pull panel from front bumper wide as possible to radiator so get funneling fresh air to radiator, even on intercooler side to slow heat from intercooler to radiator
Dividing plate in engine bay between rad and turbo to slow transfer of heat over going from block to radiator panel
if that does work get radiator flow tested, if ok, need put holes/vents in bonnet to let hot air out.
O272754663
gepsk8
Postby MAGN1T » Fri Jul 01, 2011 7:57 pm
It always amases me that people put huge big FMICs on their cars then try to figure out why the cooling system can't cope on the track?
No FMIC for me.
No overheating probs either.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby ~SlideWays~ » Fri Jul 01, 2011 9:06 pm
gepsk8 wrote:Can you move intercooler to driverside more?
Unfortunately no the intercooler can't move to the drivers side anymore than it is because the intercooler inlet is tig'd on (3" inlet cut off).
Its not actually as thick as it looks, its just a generic 76mm thick one.
The radiator is as far as it will go to the passengers side due to the intercooler piping and would need a lot of cutting.
Definitely options to make a big sheild between it and the turbo/downpipe though.
~SlideWays~
Postby ~SlideWays~ » Fri Jul 01, 2011 9:14 pm
MAGN1T wrote:It always amases me that people put huge big FMICs on their cars then try to figure out why the cooling system can't cope on the track?
No FMIC for me.
Steve
Poor old Nissan and Mitsubishi, so misguided, they'll never do well.
~SlideWays~
Postby Si » Sat Jul 02, 2011 2:01 pm
Are you trying to say that mitsi and Nissan have never used a top mount ic setup on a production car?
Current: , '96 SubaruImpreza
Si
Postby RomanV » Sat Jul 02, 2011 3:12 pm
Is there space for a proper shroud on the radiator? Will make the fan a whole lot more effective.
Postby ~SlideWays~ » Sat Jul 02, 2011 3:39 pm
Si wrote:Are you trying to say that mitsi and Nissan have never used a top mount ic setup on a production car?
The opposite, they have both fitted big FMIC's to factory cars. Which goes against the gospel of MAGN1T.
~SlideWays~
Postby Boosted_162 » Sat Jul 02, 2011 3:40 pm
I think its more that they have used front mounts standard (ie my skylines massive one)
Damn, i got beat :lol:
Postby ~SlideWays~ » Sat Jul 02, 2011 3:44 pm
RomanV wrote:Is there space for a proper shroud on the radiator? Will make the fan a whole lot more effective.
Yes possibly a thin one, although I doubt it could move as much air as driving at speed even with a big FMIC, so I'd say a shroud would only help when in the pits unless I get a top of the range electric fan maybe.
~SlideWays~
Postby allencr » Sat Jul 02, 2011 4:41 pm
Foam/rubber weather strip between the hood/bonnet and the radiator bulkhead to stop air going over, also on the top bottom & sides of the radiator between it and the bulkhead to stop air going around it.
Heatshield between the Ex manifold & radiator.
allencr
Postby strx7 » Sat Jul 02, 2011 5:08 pm
the intercooler looks like a bar and plate one, swapping to a tube and fin will allow more air thru to the radiator. Could be enough
Postby MAGN1T » Sat Jul 02, 2011 6:06 pm
the air will get through OK anyway, just that it's not cold air anymore.
Steve
MAGN1T
Postby RomanV » Sat Jul 02, 2011 6:38 pm
Do the factory fitted fmics have them in series or parallel with the radiator though? In terms of air flow.
