Psych0-hAmst3r wrote:I mostly wired up the diagnostics port today but I've hit a snag.
There are 7 wires on the OBD2 Port.
2 go into the ECU
1 is the power earth
1 is the signal earth
1 is Power from the OBD fuse (I have just used a spare 7.5A fuse)
2 Go to the MPX
The MPX is the multiplex communications box in the car which I am not running, I can always hook it up for the sake of the OBD2 port but I bet its gonna take a long time as it runs yet another fuse box and probably has a dozen different power inputs needed.
Looking at OBD2 on Wikipedia it seams that those 2 cables are needed though so guess i gotta get busy and put it in.
MAGN1T wrote:All you need is a jaycar kitset, RPM input gives a switched output at X rpms.
It can't be any harder than making mivec work on a Mitsi.
Steve
Psych0-hAmst3r wrote:well its cost me 400 bucks! sooo worth doing![]()
I will try and get a good vid on the weekend for you guys.
Going to be putting it around ruapuna next Saturday also
Leon wrote:I hate you, and I want your car.
Just wanted to share that
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
