aw11 2zzge conversion not hitting lift
Postby Psych0-hAmst3r » Wed Jul 06, 2011 10:39 am
well it looks like your onto it with the ABS stuff. Problem however is that the car doesn't have ABS, so there's no sensor at the hub to draw a signal off to stick into the ABS computer > multiplex > ECU
Guess I need to find some sort of way to imitate the signal, I can just put a microcontroller into the car but I don't know what the waveform should look like exactly.
This is getting overly complicated. Could i simply not use a microcontroller to fire the lift solenoid at 6000rpm? Or will the car have a panic attack.
Psych0-hAmst3r
Postby MAGN1T » Wed Jul 06, 2011 10:55 am
All you need is a jaycar kitset, RPM input gives a switched output at X rpms.
It can't be any harder than making mivec work on a Mitsi.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby jaypines » Wed Jul 06, 2011 12:12 pm
Psych0-hAmst3r wrote:I mostly wired up the diagnostics port today but I've hit a snag.
There are 7 wires on the OBD2 Port.
2 go into the ECU
1 is the power earth
1 is the signal earth
1 is Power from the OBD fuse (I have just used a spare 7.5A fuse)
2 Go to the MPX
The MPX is the multiplex communications box in the car which I am not running, I can always hook it up for the sake of the OBD2 port but I bet its gonna take a long time as it runs yet another fuse box and probably has a dozen different power inputs needed.
Looking at OBD2 on Wikipedia it seams that those 2 cables are needed though so guess i gotta get busy and put it in.
try to get the diagnostics working first and then borrow a scan tool. from there you can get data (speed, rpm, trouble codes etc). i think you dont need to connect the 2 mpx wires as its for some other body modules (abs, srs)...
jaypines
Postby Psych0-hAmst3r » Wed Jul 06, 2011 2:04 pm
toyota quoted me 96 bucks to plug a code reader in and see if it works... I cant afford that much money for a yes/no question.
Anybody here in christchurch have an OBD2 reader?
Psych0-hAmst3r
Postby jaypines » Wed Jul 06, 2011 2:32 pm
wow 96 bucks... go to an electrical workshop that do diagnostics. they will do it for around 40-60. some even charge less if they didnt find a fault or they cannot communicate with the car. if you were in auckland i may be able to help you with my diagnostics equipment. i think jaycar still sells one of those generic obd2 readers.
jaypines
Postby Mr Revhead » Wed Jul 06, 2011 3:04 pm
Shit for that price I'd get one of those bluetooth OBDII adaptors and use it on your phone. If you have a smart phone that is
Postby Rick » Wed Jul 06, 2011 5:09 pm
Postby Psych0-hAmst3r » Wed Jul 06, 2011 9:04 pm
well I've got a reply from paul woods and I don't need to run the onboard multiplex computer.
Also I've ordered an OBD2 reader from deal extreme for 25 bucks, I figured its so cheap that I could afford to get it wrong 3 times before it costs 1 Toyota visit...
I also went into NZEFI and they said that the speedo signal is going to be a square wave probably at 5V with a frequency of either 2 or 4 pulses per wheel revolution. So that potentially makes it quite simple to imitate if need be.
Psych0-hAmst3r
Postby matt dunn » Wed Jul 06, 2011 9:14 pm
MAGN1T wrote:All you need is a jaycar kitset, RPM input gives a switched output at X rpms.
Steve
You need the ECU to switch the lift as it will also need to change it's mapping to suit the lift as it will alter the timing and fuel slightly when lift is enabled.
Find the wire that is speed to the ecu and run a 5V sq wave speed signal to it.
The car should have a reed switch in the dash and a resistor and a 5V feed from the TPS will do it.
Postby Psych0-hAmst3r » Wed Jul 06, 2011 9:49 pm
cheers, that sounds quite do-able. And it sounds like it would work mint :)
Will be good to finally get this thing going properly. Might post a build on the forum if people are interested and I get it working.
Psych0-hAmst3r
Postby Psych0-hAmst3r » Thu Jul 07, 2011 12:19 pm
well I've now got it sorted so were all go!!
pulls bloody hard compared to the old 4age.
I do believe this is the first 2zzge swap into an aw11 in NZ?
Psych0-hAmst3r
Postby Mr Revhead » Thu Jul 07, 2011 12:24 pm
What was it in the end?
I can't say I've heard of any others.
So, whats it like mid corner when you hit 6k? :P
Postby Psych0-hAmst3r » Thu Jul 07, 2011 1:05 pm
Lol I think its prob gonna swing the rear end wide :p such a shame I don't have an LSD anymore :(
I haven't thrashed it hard around corners etc as im waiting for my new front rotors to show up, current ones are warped, I skimmed them for new pads, did a trackday and they warped on me, stupid things.
The ECU needed a speedo signal, went back to the mechanical speedo from the aw and grabbed the cable coming from the dash, I hadn't realized that there was an electrical signal already there. (Old loom is a mess from previous owners engine swap)
Makes it so much cooler having the only 1 around :p. Do need to get it certed now, should be easy enough.
Psych0-hAmst3r
Postby rx7guy » Thu Jul 07, 2011 6:58 pm
Get a rota
The torque band is wide and the road is narrow
rx7guy
Postby Nuty|Mike » Thu Jul 07, 2011 10:48 pm
got any vids of it yet ......this is the one conversion I want to do one day.
So jelous right now!!!
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby Psych0-hAmst3r » Fri Jul 08, 2011 12:01 am
well its cost me 400 bucks! sooo worth doing :twisted:
I will try and get a good vid on the weekend for you guys.
Going to be putting it around ruapuna next Saturday also :)
Psych0-hAmst3r
Postby andrewgreen1000 » Fri Jul 08, 2011 12:47 am
Psych0-hAmst3r wrote:well its cost me 400 bucks! sooo worth doing :twisted:
Is that with motosoc? I think that's when they are doing a track day? I was thinking of going for a look, sounds pretty awesome to me.
Current: '99 Ae111 Sprinter GT, '12 Aqua
Gone, but not forgotten: '81 KP Starlet, '92 Ae101 Truneo, '97 BZ-Touring Carib, '96 LWB Bighorn, '96 Bogan mobile Levin.
andrewgreen1000
Postby Leon » Fri Jul 08, 2011 8:33 am
I hate you, and I want your car.
Just wanted to share that
:lol:
Postby Psych0-hAmst3r » Fri Jul 08, 2011 10:34 am
Leon wrote:I hate you, and I want your car.
:lol:
Its all good, I understand :p Even if cosmetically its pretty ugly.
Yea its a motosoc trackday. Shame I don't have a cage or I could take you for a spin :p
Psych0-hAmst3r
