Caldina Knock sensor
Postby speedracer07 » Fri Jul 15, 2011 6:46 pm
hey guys, got a quick question to ask. The Toyota part number for the caldina knock sensor is 89615-12080, does anyone know of any other knock sensor's I could use? specifically can I use 89615-20090 which seems to be in quite a few newer toyota's.
To fill in the blanks I've damaged my knock sensor and now have the dreaded code 52 (completely my fault... was messing with the boost controller at the drag strip in direct violation of my mechanic's strict order to leave it alone and overboosted to 21.5 psi as per the alarm setting in my boost controller)
thanks in advance!!
Roshan (Toronto)
SW20 with ST215 motor (fivebob is my hero)
speedracer07
Postby strx7 » Fri Jul 15, 2011 8:56 pm
have swapped heaps of knock sensors on toyota. 3vzfe, 4afe, 4age 20v, 3sge, 2JZ etc all swapped and worked fine
Postby speedracer07 » Sat Jul 16, 2011 5:37 am
so does that mean that the issue is just if it bolts up or not?
R
speedracer07
Postby strx7 » Sat Jul 16, 2011 8:18 pm
i think that some toyota knock sensors have a bit of a loom and then the plug, the ones i have swapped have all been plug directly on sensor type. at the end of the day they all detect that exact same thing, its not as if different engines have different knock frequency or anything like that. if the shoe fits wear it.
Postby LEAKER » Sat Jul 16, 2011 9:07 pm
there's 2 main types. The only difference being the plug. However if you get the one with the wrong plug then for the love of $&#$% don't try solder a new plug on. You will never get it to work right. just find the right one. I think from memory one has an orange oring and the other doesn't. But i could be wrong. I have a minter of an ST205 that i can sell you if it fits.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Users browsing this forum: No registered users and 55 guests
