lowseven wrote: water still flows everwhere so should cool allgood regardless of head flow direction??
matt dunn wrote:lowseven wrote: water still flows everwhere so should cool allgood regardless of head flow direction??
In a standard 20V the water from the radiator flows in the back of the head, then right along the intake ports and out at the front of the head to the water pump, making the intake ports the coldest part of the engine.
If you add in the AE86 pump etc etc,
you are making the intake ports the hotest part of the engine.
lowseven wrote:this interests me... i just setup a 20v in rwd mode, ill list what i used. is there any real issues with running 20v with ae86 thermostat/water pump setup etc? i had alook at water flow etc i couldnt see any draw backs. water still flows everwhere so should cool allgood regardless of head flow direction??
so far cost me
700 - engine
70 - new toyota water pump - comes with back half/gaskets etc
free- 25mm alloy block for rear bypass, a couple of random alloy pipes to make water neck/bypass & shit i had lying round - ae86 alt setup & pulley, 3au pipe off back of thermo housing for heater outlet.
the only gay shit is where the dissy pokes out the back i have caped it off to use just the dissy sensors but its still gonna hit the LH h-core outlet/hose (ae70) & a 10mm plate under the gb mount is a waste of time also.
i can see why people front mount/side mount or chop the firewall, but i think i can use a honda or nissan heater core with afew mods or flip the heater core and run the pipes from the outher side (compartment side)and re run lines pipes around the front.
its nice to have a heater, what have you guys done
