there has got 4 studs there that do a pretty good job at locating the wheel!?! also that is why wheel nuts have a taper on them
never had any issues and never run locators. up to personal preference though
d1 mule wrote:i was running 25mm bolt on spacers that didn't locate onto the axel locator (hilux diff) and eventually caused me to loose a wheel as the spacer came off the diff, wheel was still attatched to the spacer which wasnt located either. Took maybe 4-5 days drifting for it to happen tho. more slogged out the alloy spacer on the studs if that makes sense, but yeah can happen
