2L Cambelt Issue
2L Cambelt Issue
Postby AE86less » Thu Aug 11, 2011 5:22 pm
My work van (not owned by me thank goodness!) has just $&#$% out with a cambelt issue. The belt is only about 50 000kms old and the van was serviced 4 days before.
It died as you would expect when the cambelt breaks, however once the mechanic pulled it apart he found the belt intact minus all the teeth around the crank pulley. He isn't entirely sure why this happened, there were no bolts/stones/other detritus to cause the belt to skip or seize.
Any ideas?
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Re: 2L Cambelt Issue
Postby allencr » Thu Aug 11, 2011 6:28 pm
Cam bearing seizing or loose belt, maybe tensioner bearing.
allencr
Postby Lloyd » Thu Aug 11, 2011 6:37 pm
As above, something got pretty tight. Otherwise its a belt starting to fail from oil contamination? Might pay to find out what oil was used too
Postby rollaholic » Thu Aug 11, 2011 6:44 pm
Lloyd wrote:As above, something got pretty tight. Otherwise its a belt starting to fail from oil contamination? Might pay to find out what oil was used too
no oil maybe, haha
wasnt making nunga nunga noises beforehand was it
Postby Dell'Orto » Thu Aug 11, 2011 7:48 pm
allencr wrote:maybe tensioner bearing.
Would not be at all surprised if it was this...so many people just throw a belt on when they do it, tensioners etc arent meant to last 200,000k's
Postby AE86less » Thu Aug 11, 2011 7:54 pm
We dug out the old invoice, it definately had a new tensioner with the belt. Oil was fine, proper diesel oil at the correct level etc. It's been a very well looked after van.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby rollaholic » Thu Aug 11, 2011 11:16 pm
just cos the invoice says it...
Postby AE86less » Fri Aug 12, 2011 9:50 am
This mechanic is defiantely straight up and down :lol:
I went and had a play, the only pulley that wasn't turning freely was on the end on the camshaft :roll:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Rob » Sat Aug 13, 2011 4:21 pm
From previous experience (not personal of course) sounds like that belt has done to many k's, or was far to tight which would cause a bit of a whirring sound even at idle like its pulling on a bearing
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Crucible » Sat Aug 13, 2011 9:49 pm
rollaholic wrote:wasnt making nunga nunga noises beforehand was it
hahahaha...thats classic! :D
Crucible
Real Life Mechanic
