Race seats for track use
Postby Leon » Wed Aug 31, 2011 9:24 pm
those Jamex seats are quite shit, unless they've stepped up their build quality a lot.
Postby strx7 » Wed Aug 31, 2011 9:34 pm
when it comes to things like race seats, buy the best you can afford. cheap seats feel like cheap seats when you sit in them for hours, they also react like cheap seats, should/when you crash
Postby siren676 » Wed Aug 31, 2011 9:41 pm
Are there any good quality brands which do reclinables? I wouldnt want to be constantly swapping between a road and dedicated race seat for every meeting.
siren676
Postby Dell'Orto » Wed Aug 31, 2011 9:42 pm
Bride do I think? Though whether they'd be FIA approved I dont know
Postby siren676 » Wed Aug 31, 2011 9:42 pm
Ill check their website
siren676
Postby wde_bdy » Wed Aug 31, 2011 9:48 pm
A couple of Bride seats would buy you a new car last time I looked. :lol:
Callum
wde_bdy
Postby siren676 » Wed Aug 31, 2011 9:50 pm
1 would probably be worth twice what my cars worth :lol:
siren676
Postby Leon » Wed Aug 31, 2011 10:10 pm
do you need reclinable?
Just keep the factory seat in the passenger side for easy access if required
Postby siren676 » Wed Aug 31, 2011 10:14 pm
Its a 5 door so they don't need to be reclinable, I'd just prefer something with a little bit of adjustment if its uncomfortable. Are fixed back seats legal for road use/easily wofable?
siren676
Postby wde_bdy » Wed Aug 31, 2011 10:21 pm
99% chance you will need a cert for aftermarket seats.
Callum
wde_bdy
Postby Boosted_162 » Wed Aug 31, 2011 10:24 pm
+1 for buying quality seats. Ive used Jamex reclinables, a Bride Zeta I and a Zeta III FIA. TBH, the Jamex were uncomfortable, the Zeta I was a piece of shite, but the Zeta IIIs are the most comfortable seats ive ever sat in (better than both my GTR seats and Evo 8 ones)
Not cheap at $1k tho :lol: but ill never buy a cheap seat again.
Postby siren676 » Wed Aug 31, 2011 10:25 pm
:( ah well, ill be getting a cert for whenever i do the motor swap so ill have to do the seats at the same time :wink:
siren676
Postby 1I1 » Wed Aug 31, 2011 10:58 pm
Dell'Orto wrote:Bride do I think? Though whether they'd be FIA approved I dont know
Pretty certain I've seen Mac state no reclineable Bride seats are FIA approved. Thats how you can tell fake Brides apart as they usually state they are from memory
TRD Clicky >>Here
1I1
Postby Truenotch » Wed Aug 31, 2011 11:14 pm
They're still not legal under MSNZ rules for National level - the manual states fixed back AFAIK.
Still fine for clubsport.
Best luck I've had is buying second hand seats for reasonable prices. My sparco was only $100 when it popped up (in faded red). I had it re-covered and it was good to go.
If it's a road car then make sure you get a well made seat with good padding.
Truenotch
Postby RobertC » Wed Aug 31, 2011 11:36 pm
So would you need a cert for a bucket seat bolted to this?
http://www.upgarage.com/upgarage/stock/1/2/1106126005000/126
RobertC
Postby wde_bdy » Wed Aug 31, 2011 11:44 pm
No you wouldn't, however the cost of those rails seemed to be dearer than a cert last I looked.
Calluj
wde_bdy
Postby siren676 » Wed Aug 31, 2011 11:56 pm
Ive been quoted $580ish for a cert for prety much everything im planning for the car in the immediate future. If i have to get fixed back seats so be it, ill get them installed at the same time as the engine.
siren676
Postby touge_ae101 » Thu Sep 01, 2011 12:02 am
you don't need a cert as long as it is mounted using the factory rails and bolts to the factory points. the line is a bit blurry but i say don't bother wasting money on cert there are more important things to spend money on.
don't even bother with reclinables they just aren't strong enough for motorsport use.
+1 for second hand good quality seats. or get a racetech. the 1000 series seats like mine are pretty affordable and comfortable so you won't need to change for road use. after daily driving my car i feel uncomfortable going back to a normal road car seat they just don't hold you in as well.
touge_ae101
Postby RobertC » Thu Sep 01, 2011 12:03 am
wde_bdy wrote:No you wouldn't, however the cost of those rails seemed to be dearer than a cert last I looked.
Calluj
Huh? The rail would be about $130 NZ landed. Considering he will need a rail anyway. Why not get one that bolts straight in?
RobertC
Postby siren676 » Thu Sep 01, 2011 12:13 am
touge_ae101 wrote:you don't need a cert as long as it is mounted using the factory rails and bolts to the factory points. the line is a bit blurry but i say don't bother wasting money on cert there are more important things to spend money on.
:lol: You should have seen the stock seats ep91's came with, i was having to adjust myself after even slight corners on the road.
Ill keep my eye on trademe for a decent 2nd hand seat in auckland so i can have a test fit and see how comfortable it is.
I have to get a cert anyway for an engine swap so i may as well get the seats done at the same time.
Ill see on the 11th what the scrutineer says about my current seats and go off what he recommends i should do.
siren676
