caldina headgasket (no magn1ts allowed)
Postby rollaholic » Tue Sep 06, 2011 3:48 pm
did have a quick search but nothing jumping out at me - is replacing the headgasket on a ST215 GTT an engine out job? i know the clutch and cambelt are supposed to be.
if its not, would it be relatively straightfoward to do without a hoist.
cheers :)
Postby strx7 » Tue Sep 06, 2011 5:48 pm
it is would be possible to do it in car unless it has ARP head studs which will make it almost impossible to get the head on and off. but it would make life easier to remove it from the car to do it
Postby loudstealthGT-Four » Tue Sep 06, 2011 6:58 pm
yip you can replace the headgasket with the engine in the car. done it not long ago
loudstealthGT-Four
Postby rollaholic » Tue Sep 06, 2011 7:09 pm
yeah, i've no doubt having the engine out would make it easier :) - just wondering if its a time saver or not (time of removing and replacing engine vs extra hassle caused by leaving it in)
did you do it on the ground loudstealth, or did you have a hoist?
Postby loudstealthGT-Four » Tue Sep 06, 2011 7:37 pm
rollaholic wrote:yeah, i've no doubt having the engine out would make it easier :) - just wondering if its a time saver or not (time of removing and replacing engine vs extra hassle caused by leaving it in)
yip just did it on the ground, all we done was just take the head off and put the new headgasket on and then put the head back on, but it was on a mates car and he was in a rush to get it done. And it was the first time id ever replaced a headgasket
loudstealthGT-Four
