Doesn't really help you with your problem, but are you the guy I've been talking to about getting an N1 connector from?
Maximum wrote:.
I'll join those plugs for the air con fan too, so that the second fan isn't running all the time.
The other thing I need to sort out is why the first fan is on all the time. Something to do this weekend...
LEAKER wrote:Maximum wrote:.
Joining the plug wiring will stop the fans that are triggered from the coolant temp. Don't ask me why, someone else can explain why I'm sure but I had to do it on my gt4 when I removed the a/c. They're linked somehow. Presumably through the ecu.
