Intercooler pipe flaring/ridging
Postby buriedalive » Thu Sep 29, 2011 5:10 pm
So I've made up my new aluminium intercooler piping, had some welded but need the ends flared/ridged to stop the silicon joiners sliding off under boost. Who does that? Exhaust shop? Pitstop? Guttering installer?
buriedalive
Postby Bling » Thu Sep 29, 2011 5:12 pm
Anyone that welds aluminium should be able to do it.
Postby XSVWGN » Thu Sep 29, 2011 5:40 pm
Alloy is soft and might crack. I ran into this problem so i just had my welder weld an alloy bead around the edge of the pipe. I run decent power and have never had any trouble with pipes coming off
Matt
2008 Kia rio - work car
XSVWGN
Postby Quint » Thu Sep 29, 2011 6:27 pm
^^ As above, works.
Quint
Re: Intercooler pipe flaring/ridging
Postby Mr Ree » Thu Sep 29, 2011 7:18 pm
buriedalive wrote:So I've made up my new aluminium intercooler piping, had some welded but need the ends flared/ridged to stop the silicon joiners sliding off under boost. Who does that? Exhaust shop? Pitstop? Guttering installer?
How much boost are you planning on running, and what turbo?
Before I went na-t, I read plenty of storys about couplers popping off, but I expect alot of it will be a case of loose/cheap clamps.
For what its worth, Ive never popped a coupler off but Im only running 11/12psi through a small T4.
wak thud gush!
Mr Ree
Postby h8wrxs » Thu Sep 29, 2011 7:33 pm
ive popped silicon joiners off on both my evo and my gtx, the gtx would do it as soon as i spooled up to about 14psi...
i think its worth getting the ends lipped/flared
The four seasons in Australia consist of "$&#$% it's hot", "Can you believe how $&#$% hot it is?", "I won't be in today because it is too $&#$% hot" and "Yes, the dinner plate size spiders come inside to escape from the heat."
h8wrxs
Location: travelling to candy mountain with my magical leoplurodon
Postby Malcolm » Thu Sep 29, 2011 7:49 pm
You really want to find someone with something similar to this:
You can buy here
http://www.beadform.com/product.html
Similar ones here
http://shop.useful-tools.co.uk/hand-bea ... ol-4-p.asp
And some DIY ideas here
http://www.dsmtuners.com/forums/custom- ... -tool.html
You could also try a few sheetmetal places to see if they have bead rollers, they might tend to be this style:
And the rollers may be too large to fit inside your pipe
Postby MAGN1T » Thu Sep 29, 2011 8:24 pm
I've got pipes wired together with tabs welded onto the pipes. They'll never blow apart. Don't need ricer hoseclamps either.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby Dell'Orto » Thu Sep 29, 2011 8:35 pm
Cause jubilee clips are soooooooooooooo rice. Damn those factory ricers!
Postby buriedalive » Thu Sep 29, 2011 8:44 pm
Not sure about boost levels yet as the 1J is only running 2JZ injectors with the T04Z but that bead roller is exactly what I was thinking of. If I don't go that route I'll probably get a lip welded on the ends. Cheers
buriedalive
Postby evil_si » Thu Sep 29, 2011 8:52 pm
I have a bead roller, also referred to as a croxing tool for plumbers
With alloy pipes I find it best to use standard type hose clamps, T bolt clamps have a bad habit of deforming the soft alloy pipe even at relatively low torques
evil_si
Postby kiwi4agze » Thu Sep 29, 2011 8:54 pm
Use aircraft alloy pipping, You can get it in different sizes, not that expensive and some weird angles... I am using it to hook my intercooler up to my supercharger. Easy to join and very strong and light.
kiwi4agze
Postby Mr Ree » Thu Sep 29, 2011 9:03 pm
Thats an interesting fact about the t bolt clamps deforming soft alloy pipes, cheers for that tidbit evil si :)
I have 3" stainless steel so I dont think I can crush that.
I guess I should take advice and get my pipe ends beaded so I dont find out the hard way why people do it. I plan on increasing boost a few psi once the new box goes in so I may as well pre empt the issue.
wak thud gush!
Mr Ree
Postby Malcolm » Thu Sep 29, 2011 10:08 pm
evil_si wrote:I have a bead roller, also referred to as a croxing tool for plumbers
I've heard them referred to as croxing tools too, but google didn't seem to agree. I usually borrow Alert Motorsport's one, it's a bit simpler than the ones I posted and looks like it would be cheaper - is it likely that plumbing supply shops would carry them?
Postby Malcolm » Thu Sep 29, 2011 10:10 pm
MAGN1T wrote:I've got pipes wired together with tabs welded onto the pipes. They'll never blow apart. Don't need ricer hoseclamps either.
Steve
Sounds like a pain in the ass to work on. But at least you're not a ricer with hoseclamps n shit.
Postby Mr Ree » Thu Sep 29, 2011 10:23 pm
Do I need to take off my hose clamps now?
I dont want to be a ricer
confused :?
wak thud gush!
Mr Ree
Postby XSVWGN » Thu Sep 29, 2011 10:34 pm
I run T-bolt clamps on my alloy piping and run 18-23psi at the moment and havent had any problems with pipes changing shape etc now pipes blowing off and i only have small beads around the ends of pipes ....
XSVWGN
Postby Mr Ree » Thu Sep 29, 2011 11:05 pm
All good mate, I was just being cheeky. ;)
wak thud gush!
Mr Ree
Postby GOLDAE86 » Sun Oct 02, 2011 4:13 pm
The tool required is called a Jenny or swaging tool. Hope that helps
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby thegreatestben » Sun Oct 02, 2011 4:47 pm
My piping just had a few runs of weld on the ends of the piping, don't need to run a bead all the around. No problems at 20 psi with normal hose clamps or T bolt clamps
thegreatestben
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 16 guests
