iamawesome wrote:Just round ones, where abouts are they?
Looonie wrote:Where the lower control arm bolts to the hub is just a removable ball joint that connects with three bolts to the lower control arm...
So its not the bushings but play in the balljoint they failed you on?
From memory they were only $60 each new from Toyota when I replaced mine (back in medieval times when my car actually went).
