Cleaning off aluminium oxide?
Postby Dell'Orto » Mon Oct 31, 2011 7:42 pm
So the AFM from this MR2 has been sitting inside the boot for a while, and has built up a bit of oxidisation on the inside. Is there any way other than sanding to get it off??
Postby ee904age » Mon Oct 31, 2011 8:08 pm
Oven cleaner worked for me on some motorbike bits, prob not so good around plastics/electronics though.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Grrrrrrr! » Mon Oct 31, 2011 8:10 pm
Dont try the leave it soaking in Coke trick that coin collectors use for coins.. it just makes ali oxide turn brown :)
Grrrrrrr!
Postby iOnic » Mon Oct 31, 2011 8:14 pm
Wire brush it and clean out with AFM spray
Postby Soiled » Mon Oct 31, 2011 9:21 pm
Try contact cleaner, it's what I've always used on AFMs. Don't know how bad your build up is though.
Soiled
