Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey wrote:to reset the engines fuel gearshift computer you must start the car, turn off the car, take out the key then toot the horn 5 times.
~SlideWays~ wrote: running 91 in it/short trips to the dairy every 30min.
Tagged wrote:~SlideWays~ wrote: running 91 in it/short trips to the dairy every 30min.
oh! I posted a question somewhere long time ago asking if 91 is okey for 4AGEs and most responses were positive. What are the affects of using 91 in 4AGEs??
Tagged wrote:mr_monkey wrote:to reset the engines fuel gearshift computer you must start the car, turn off the car, take out the key then toot the horn 5 times.
I tried it this morning 5 times but all it did was woke up some pissed off neighbours..... D:
Mr Revhead wrote:fill it right up to the brim, then drive and record kays. then record exact amount to refill it.
you will need to do that for at least 3 tanks.
Otherwise your figures will mean 0
No 50l. And empty light is supposed to come on when there is 8l left in the tank.Tagged wrote:Mr Revhead wrote:fill it right up to the brim, then drive and record kays. then record exact amount to refill it.
oh yea I've actually done that before too. probably should do it again for accuracyif i remembered right, BZR's have 55L tanks right??
mr_monkey wrote:Tagged wrote:mr_monkey wrote:to reset the engines fuel gearshift computer you must start the car, turn off the car, take out the key then toot the horn 5 times.
my work here is done
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
