Big 3sgte service. What to do.
Postby Al » Tue Nov 08, 2011 10:49 pm
Right, next weekend, if I play my cards right I'll be dropping the mr2 engine out for its 2nd big service.
I have a new entire gasket/seal kit, although I probably won't use most of it.
TGP cambelt, waterpump, fuel filter, idlers, tensioners, ac belt, alt belt.
I have a ct20b to go on, with my Berk downpipe as well and I have an enormous K&N filter that I picked up for a song that I will place in the passenger vent.
Is there anything else I should change while the engine is on the ground?
Al
Postby Akane » Tue Nov 08, 2011 10:55 pm
change the entire engine to a Gen 3.
Postby Al » Tue Nov 08, 2011 11:06 pm
Akane wrote:change the entire engine to a Gen 3.
Prob do that next project. I'll just get this running better first and tidy it up.
That half cut on Trade Me is tempting, just need a tidier shell to drop it all into.
Al
Postby Dell'Orto » Tue Nov 08, 2011 11:08 pm
HFH for sure, do rear main also even if you dont do clutch
Postby Al » Tue Nov 08, 2011 11:25 pm
Cool just emailed away for pricing on HFH and HFHOE. Clutch change is ez mode, will see how the stocker holds up, seems quite strong at the moment from my launching practices 8) So can change later.
Al
Postby Grrrrrrr! » Tue Nov 08, 2011 11:41 pm
CV boots, ball joints, gearbox output shaft seals?
Grrrrrrr!
Postby Al » Tue Nov 08, 2011 11:48 pm
Should have the axle seals in my kit 8)
Getting CRW CV outers in due course for drag racing duties 8)
Al
Postby iOnic » Wed Nov 09, 2011 6:02 am
BEB
Postby Malcolm » Wed Nov 09, 2011 8:43 am
Al wrote:Should have the axle seals in my kit 8)
Unlikely, you don't usually get them as part of a TGP engine gasket set, and probably same deal for non-genuine
Postby Al » Wed Nov 09, 2011 7:34 pm
iOnic wrote:BEB
Yup since they can be done with the crank in place it could be a winner. Will go TGP.
Al
