Head Unit Fail
Head Unit Fail
Postby BZG Wagon » Sun Nov 13, 2011 2:27 pm
Bought a head unit out of the states - checked the frequency range before I purchased but I didn't realise they step in odd numbers (i.e. 89.9, 90.1, 90.3 etc. vs NZ 90.0, 90.2, 90.4 etc.).
I've heard rumors you can change Sony headunits by hiting a combo of keys on the faceplate - has anyone had experience with this?
The other alternaitve will be a 0.1mhz band shifter.
It's a Sony MEX-BT3900U
BZG Wagon
Postby DeeCee » Sun Nov 13, 2011 3:56 pm
generally it is a selector switch to change from US to international. Could be inside the unit. Otherwise you are out of luck
GT Four Adovansu
DeeCee
Postby matt dunn » Sun Nov 13, 2011 5:36 pm
blaupunkt stereos are done in a menu , it's a feature called FM step.
Maybe in the manualof yours?
Postby DeeCee » Sun Nov 13, 2011 7:55 pm
i have already viewed the manual and installation guide and there is nothing there about selectable regions for FM modulation
GT Four Adovansu
DeeCee
Postby matt dunn » Sun Nov 13, 2011 7:57 pm
DeeCee wrote:i have already viewed the manual and installation guide and there is nothing there about selectable regions for FM modulation
Probably can't be done then.
You will find that it will get stations but not others.
