stuck outer tie rod
stuck outer tie rod
Postby DeeCee » Sun Nov 27, 2011 5:32 pm
So I'm in the processing of replacing my outer tie rods. Rack is out of the car (like every other part) and I've loosen the jam nut, but the tie rod won't screw off. Any one got some tips to help?
GT Four Adovansu
DeeCee
Postby DeeCee » Sun Nov 27, 2011 5:55 pm
got it - some really good hammer skills to shock the body of the unit and it finally came off - yay :)
GT Four Adovansu
DeeCee
Postby Dell'Orto » Sun Nov 27, 2011 7:53 pm
FBH fixes all 8)
Postby DeeCee » Sun Nov 27, 2011 8:08 pm
seems that way sometimes. Though if this was on the car, what would work instead? I'd be scared to bend the steering arm with the force I hit the tie rod body with
GT Four Adovansu
DeeCee
Postby Bling » Sun Nov 27, 2011 8:25 pm
Gas axe 8)
Or CRC times lots
Postby rollaholic » Mon Nov 28, 2011 6:39 am
chop it!
Postby Lurkin » Tue Nov 29, 2011 12:13 am
leave ball joint attached, spray with penetrate goodness and hope it will come undone (it didn't). thought of cutting it off/ grinding it down but doubted my ability to miss the thread of the inner tie rod.
In the end I replaced inner and outer after finding that someone else had already had a go, with what looked like vice grips on the threads.. :roll:
Past casualties
1986 4age liftback (sold)
1985 4age aw11 (well crunched)
1993 ae101 gt apex levin (sold)
Lurkin
Postby Lloyd » Tue Nov 29, 2011 7:17 pm
DeeCee wrote: I'd be scared to bend the steering arm with the force I hit the tie rod body with
You never hit the tie rod body, you hit the hub that the taper goes into
And yeah if you're hitting the tie rod you'll be there for ages, if you hit the bit it goes into it should just pop out with a couple of decent hits
Postby DeeCee » Wed Nov 30, 2011 6:43 am
the tie rod body was stuck on the steering arm itself, not stuck in the hub carrier. Rack was already removed.
GT Four Adovansu
DeeCee
