correct wheel off set
Postby stacy » Tue Dec 06, 2011 9:01 pm
Hey guys, i am looking at some second hand alloys and im just curious as to the correct off set for an AE82 fxgt the wheels in question are 17x7 and the off set i 'think' is 42 will this work? cheers
stacy
Postby Mike- » Tue Dec 06, 2011 9:32 pm
sounds about right
Mike-
Postby pc » Tue Dec 06, 2011 10:44 pm
I'm pretty sure the correct offset is 35. My AE82 doesn't really like any of my 15x6.5 wheels around the 42-45... rubs when on full lock.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby stacy » Tue Dec 06, 2011 10:58 pm
Cheers guys i have just test fitted them had had to put a camber bolt in the rear to clear strut and spring cup gave it some positive camber and now clears by a little, no hitting on full lock but its just standard height at the mo, how close is too close?
stacy
Postby RobertC » Tue Dec 06, 2011 11:07 pm
stacy wrote:Cheers guys i have just test fitted them had had to put a camber bolt in the rear to clear strut and spring cup gave it some positive camber and now clears by a little, no hitting on full lock but its just standard height at the mo, how close is too close?
Your best bet would be to put in some longer studs and run some 5mm slip on spacers.
MRAE111 wrote:ok thanks guys but wen u dont have trmpets i think the air flow quickeer into the throttle bodies
RobertC
Postby levinguy » Tue Dec 06, 2011 11:14 pm
if it doesn't hit on full lock why would you change it as long as the alignment is not crazy or anything
levinguy
Postby AE82 FXGT » Tue Dec 06, 2011 11:33 pm
dicking around with camber or any suspension setting to make wheels fit is a bit silly imo (my opinion being qualified mechanic with AVI cert)
AE82 FXGT
Postby phoenix » Tue Dec 06, 2011 11:52 pm
AE82 FXGT wrote:dicking around with camber or any suspension setting to make wheels fit is a bit silly imo (my opinion being qualified mechanic with AVI cert)
That and putting 17s on an AE82 at all, let alone a stock height one. 15s are where it's at for these imo.
phoenix
Postby Bling » Wed Dec 07, 2011 12:14 am
How is this the "best bet"? Sure it might work, but the car will then be uninsured and should fail a WOF for the modification. Not exactly ideal neil just for the sake of fitting some rims. Unless it's a race car that doesn't hit the road.
Best bet is usually the get the right wheels that fit. If its not hitting now though on full lock I wouldn't worry.
Postby AE82 FXGT » Wed Dec 07, 2011 11:25 pm
This. Get some nice lightweight 15s on that shit
AE82 FXGT
Postby tsoob » Thu Dec 08, 2011 11:56 am
yep those are the right wheels.
17x7 35p is not right for that car.
BUT 15's are a WAY better option. 15x6.5 at 38p ideally
If you must run 17's (ghey) then you will most likely need a 3mm spacer
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby xsspeed » Thu Dec 08, 2011 12:05 pm
Why do you say 35p on a 7 inch rim is not right? Anything over 40 with a 7inch will be very close to the rear strut.
Here's my 15x7 42p mags sitting on the back of my ee80 for a mockup
It's all but touching the strut
Postby strx7 » Thu Dec 08, 2011 12:46 pm
35mm and you will probably need to the roll the guard lip and encourage it outwards a fraction. 7 inch, 38mm offset is pretty much the ideal rim for the back of any 80/90/100 series corolla
Postby Bazda » Thu Dec 08, 2011 1:23 pm
15/16x8 +25-30 is where its at
Postby tsoob » Thu Dec 08, 2011 4:14 pm
strx7 wrote:35mm and you will probably need to the roll the guard lip and encourage it outwards a fraction. 7 inch, 38mm offset is pretty much the ideal rim for the back of any 80/90/100 series corolla
this
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby xsspeed » Thu Dec 08, 2011 4:47 pm
Rolling guards is easy, spacers mean cert is required legally (even slip on), agree 38p on a 7" wide rim would probably give you enough space either side.
And also agree you should be using 15's on an ae82 :lol:
Postby AE86less » Thu Dec 08, 2011 4:54 pm
xsspeed wrote:And also agree you should be using 15's on an ae82 :lol:
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby xsspeed » Thu Dec 08, 2011 4:56 pm
AE86less wrote:
xsspeed wrote:And also agree you should be using 15's max on an ae82 :lol:
Edit
Postby stacy » Thu Dec 08, 2011 6:30 pm
Man i was unaware fitting wheels was such a mission all good points there guys i was going this way as the wheels were cheap and local, ie young guy who sweeps our workshop, as for mucking around to fit them how will fitting camber bolts make it unsafe? i am also a qualified mechanic and wof inspector and see no danger unless is excessive camber and it will also not be staying at stock height, i also have a wheel alignment machine at my disposal so any issues will be sorted before venturing on to a public road, so in saying all that is there any one who has wheels in a smaller size and better offset that i could look at cheers
stacy
Postby tsoob » Thu Dec 08, 2011 7:49 pm
run spacers over the camber option.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
