wde_bdy wrote:Be careful on floor area, I know local to me over 10m2 permanently attached to the ground requires a permit. My garden shed is built out of 50x50, each wall built separate then stood up and screwed together along with a roof panel. Built on on an upside down half round base so totally moveable as required.
Callum
Callum
FST4RD wrote:Hey all,
Building a garden shed for the other half.
Was going to build it using 100x100 for the 4 corner posts. Was going to make it 2.6m out of the ground, plus a third undergroud I would need 4m lengths. Most places I have rung or been to only have it in 3m lengths.
I would use 100x75 at a push which I can find in 4m lengths, but most of the stuff I have found is pretty bowed, not good.
Anyone know where I can find 100x100 rough sawn in 4m lengths?
The shed base isn't going to be square, front will be 2.6m, back 1.7m, one side 3.6m and the other side 2.9m and 2.6m high. This is to fit into a specific area.
Am I going overboard with 100x100 for the 4 posts for this project?
wde_bdy wrote:1. Delay shed build
2. Poison tree
3. Cut out dead tree
4. ??????
5. Profit
wde_bdy wrote:There are 130 trees missing from my place, most of which were supposed to make my life not worth living. Replacing with the latest fad tree and you will be sorted, productive fruit trees/berries work best.
Callum
fangsport wrote:1.3m into ground is super overkill, not even required that deep (unlees in shite ground) for anchor pile in a timber framed floor.
any decent timber merchant should have 4 x 4 in 3.6m lengths.
scan and email your plans and will advise any necessary changes
Return to Christchurch / Upper South Island Region
