broke the clockspring in my chaser...where to get a new one?
Postby Tha_INS » Thu Jan 19, 2012 4:40 pm
replaced the bus steering wheel in my chaser with an altezza 3 spoke one. failed to read instructions about re assembly written on the clock spring itself. After re assembling i couldnt get full, lock turning left so I forced it and felt something snap.
Searching the web i found out that i probably broken the ribbon cable inside the clockspring.
Know where to get one? Anyone ever fixed one?
Currently rocking 1G-FE power
Tha_INS
Postby matt dunn » Thu Jan 19, 2012 5:53 pm
Not repairable and probably $500 + from toyota.
We have done heaps at work on toyota's, but not a chaser specifically.
Maybe try wreckers for a S/H one?
Postby Tha_INS » Thu Jan 19, 2012 6:11 pm
yeah north shore toyota quoted me $300 excl GST....will goto wreckers and see if they have
Tha_INS
Postby Bling » Thu Jan 19, 2012 7:01 pm
Try the sponsors section on here. Unless that was a good deal from Toyota.
Postby rollaholic » Thu Jan 19, 2012 7:11 pm
thats a mistake you only make once :)
Postby Tha_INS » Thu Jan 19, 2012 9:16 pm
yeah man tell me about it have only replaced steerings wheels on older cars without airbags so this is my first time doing it on an airbag one...
apparently they retail in NZ for nearly $1k so yeah $300 was the best deal they could do for a new one
Tha_INS
Postby strx7 » Thu Jan 19, 2012 9:36 pm
what model chaser?
Postby Tha_INS » Thu Jan 19, 2012 10:10 pm
jzx100
Tha_INS
Postby strx7 » Fri Jan 20, 2012 6:37 am
try ringing Taranaki Partsworld.
Postby Jason T » Fri Jan 20, 2012 6:54 pm
Tha_INS wrote:yeah man tell me about it have only replaced steerings wheels on older cars without airbags so this is my first time doing it on an airbag one...
Clock spring ribbon is a universal Toyota part :roll:
Can you solder ?? is a easy fix depending were its has pulled the contacts out
Take the cover off solder contacts back in place save $300 :lol:
Fixing Toyota's since '87
Jason T
Postby Tha_INS » Fri Jan 20, 2012 9:53 pm
Yeah I can solder but not the best at it, may give it a crack anyway since its broken.
Gave Taranaki partsworld a call they had one in a jzx100 but werent sure if it was still working. Said they would call me back I have left a number but still nothing
Tha_INS
Postby Tha_INS » Fri Jan 20, 2012 9:57 pm
i've also been wondering if clocksprings from other toyota cars would fit?
say a camry, cause my mum has a camry with exactly the same stock steering wheel
Tha_INS
Postby matt dunn » Fri Jan 20, 2012 10:42 pm
Tha_INS wrote:i've also been wondering if clocksprings from other toyota cars would fit?
Use toyodiy
find the part number for it,
then reverse search by part number for all the cars it fits.
Postby Tha_INS » Sat Jan 21, 2012 6:17 pm
Use toyodiy
shot matt you are the man.....turns out kzn185 surf uses the same one and someone on TM has one for sale....score $45
Tha_INS
Postby Tha_INS » Wed Jan 25, 2012 6:08 pm
turns out the kzn185 one is a slightly diff part number (1 digit) off. But it still works all the connectors are in the same location. Thanks toyspeed, I love toyotas so much interchangeability
Tha_INS
